Question about Hisense Televison & Video
Hisense remote not responding to button input, only the power button responds, nothing else, how can this be fixed. TV model is 43P6 Hisense 43 Series 6UHD HDR, changed batteries already
SOURCE:
SOURCE: TV suddenly doesn't respond to Sony remote & power button on Satellite remote.
I am having the same problem with the "initial setup" screen flashing repeatedly/ intermittently. It's not a problem with the remote. In the research I have done online, it seems as though this is a common/known problem with the Wegas that will require a service visit. Apparently the problem is a defective receiver chip. The best thread I found is at: http://www.agoraquest.com/viewtopic.php?topic=15393&forum=34&start=0&select_page_number=1 I've seen some speculation that it is caused by windex or cleaning fluid dripping down when the screen is cleaned and corroding one of the internal components. That's not applicable in my case, since I always just clean the screen with a microfiber dusting cloth. So, I guess I will be calling a repairman and spending $$$ to fix as it is now flashing up so often as to be unwatchable. Ridiculous, I think, given that my TV is only 3 years old!!
Posted on Jan 11, 2007
SOURCE: My TV has stopped responding to the remote control (and the universal remote) and the front panel buttons don't work
waynejman, I have the same exact problem, can you tell me what your outcome was?
Posted on Nov 16, 2008
SOURCE: My Sony Trinitron TV does not respond to remote control commands
the tv wont come on the standy timer light is on
Posted on Jan 02, 2009
  • 476 Answers
SOURCE: cannot change input source for tv
i would try the abvious first, unplugg the tv from the ac outlet and wait for a few seconds then try turning tv on see if the problem is solved, if not it might be that the key board panel needs replacing.
Posted on Aug 02, 2009
budmrtn
  • 11361 Answers
SOURCE: TV doesn't respond to the remote control...can't change channels
You have to find out if the remote is sending out the infrared signal to the TV remote receiver or not, you can test that by pointing the remote at the digital camera, you should see flashing light on the camera screen when any one of the remote button is pushed (digital camera can detect infrared light). If get the flashing light then the problem is in the TV remote sensor.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 15, 2010
My Hisense 55H8C TV does not respond to remote control or power button. If I switch on the main power plug, the tv is stuck at the last channel and sound output is through soundbar only. I have to switch...
Lots of modern electronics can be repaired by simply unplugging the AC power from the outlet and leaving it unplugged for 24 hours before plugging it back in.
Explanation... modern electronic devices are never truly "OFF" unless the power is completely removed. A logic state will get stuck and the easiest way to un-stick it is remove the power from the device long enough to discharge all of the capacitors on all the circuit boards.
Oct 09, 2018 | Hisense Televison & Video
Hisense TV model #40H5 won't respond to remote or buttons on TV.Ive tried changing Input,channel,adjusting volume & turning TV off.
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Feb 11, 2017 | Hisense Televison & Video
My tv is on the photo screen and can't get it back to normal tv. I've tried everything and nothing has worked
The source button on your remote should cycle thru the various inputs. If it doesn't respond make sure the lock button (child lock) hasn't been pushed and engaged on the remote.
Jul 31, 2015 | Hisense Televison & Video
How do I fix my new TV which will sometimes lock up and will not respond to some buttons on the remote or the TV itself?
it is under 1 year warranty from the manufacturer,contact them for repair,they will send someone to you
May 24, 2015 | Televison & Video
Hisense tv model number LCD42v68p is not responding to remote and menu buttons screen comes on with alphabetical letters how do i fix that
Hi, Try puting new batteries in remote. Make sure remote has clear view of TV censor. Remote maybe damaged in side replace with new one. Good luck.
Aug 07, 2014 | Televison & Video
Haier HLH406BB 40 in. LCD HDTV - tv will not turn on. is not responding to either panel or remote power buttons. red off input light is still lit.
hi sounds like a power supply fault could be capacitors, look for tech in your area good luck
regards
shaun
Jan 15, 2014 | Televison & Video
Hisense W58, no picture
Check and replace its main digital processor board.
Jul 19, 2013 | Televison & Video
Hello, I recently purchased a Hisense LCD TV - model LCD42V68PCA. It has a USB drive plug-in but I cannot seem to get it to respond. I inserted it but nothing happens. Do you have any suggestions? Thank...
Hi Mr Baker,
If you go through the user manual of your TV you will not find USB in the input list. So this TV does not support USB input. The USB port is for software updates. I hope it helps.
Feb 06, 2018 | Hisense Televison & Video
Televison & Video Logo
60 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Paul
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
