SOURCE: lights blinking
I have a 3122 and had a similar problem, Lights flashing, humming noise and me standing there scratching my head! I emptied all the water out of the filter basket and then tilted the machine backwards (only needed about 20 degrees) and then the rest of the water drained all over the floor... about 1/2 a liter. Now its all good! and the missus is nun the wiser!
SOURCE: model 1485 asko dishwasher. Wont
If there are no lights on the display i.e ' dead ' - it is highly suggestive of faulty control board. You need to replace the control board. Once replaced, it would fix the problem.
Unfortunately, there is no reset or fuse that could fix this situation.
You should bear in mind that there may be an underlying cause for the failure of the control board.
If there is then simply fitting a new one may result in the new board blowing.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: Asko Dishwasher D1896. Program appears
Hi You can leave it unplugged for 30 minutes to reset it, if
the issue returns then it seems that the issue is with the door latch mechanism
or the control board itself going bad and should be replaced. Hope this
helps...please post back for further assistance. Daniel
SOURCE: built in asko dishwasher lights
Hello, welcome to FixYa.
Based on your post I understand you have an Asko dishwasher, first off I'd like to verify the model number and second the symptoms or status.
You said the lights along the top do light. yet the unit will not start when you select a cycle and the door is closed, correct ?
There are a few possible scenarios (depending on the model of Asko) so I'll need to clarify the model before moving forward. Anything thing else you can add is beneficial.
Regards,
Macmarkus :)
