SOURCE: NAKAJIMA AE-800
hitting "code + /" puts ribbon drive mode into multi-strike ribbon mode, to correct this hit "code + ."
SOURCE: The ribbon is not moving for each new letter being
I'll try thisagain use the code key with one of these 3 keys ,.
. , or / this will take you out of the uverstrike ribbon mode.
DickyO
SOURCE: Nakajima typewriter model AE830. New ribbon
Check to see if the ribbon is moving, then advance the ribbon manually about 6 inches, the ribbon may be old and they do go bad especially the exposed part. If the ribbon isn't advancing Code peroid, comma or slash will get you out of the overstrike mode.
DickyO
SOURCE: I have a WPT-160 Nakajima
I don't know if the 160 has a stencil mode. Go to NADIST.COM, click on current models you will find an instruction book there.
DickyO
SOURCE: DOESN'T SEEM TO HIT HARD ENOUGH ON RIBBON TO MAKE
could be a defective ribbon, try new one if it looks like the letters are almost typing on top of each other on the ribbon. it could be a problem with the ribbon drive of the printhammer. if a new ribbon doesn't help, get professional help.
