SOURCE: Flat panel displays half screen, mirrored on bottom half of screen
Have several problems with either a bad LVDS cable from Main unit to the LCD controll bd. Sometimes the cable is just not connected properly. If you reseat this cable and the problem still exists you most likely have a bad LCD control bd.
SOURCE: Hello, My babysitter was playing Wii
Unless you are a techician, you need to go to a repair shop this is no easy fix it yourself problem,ThankYou for using FixYa. Have a Nice Day.
SOURCE: Top Half of monitor is brighter than the bottom half
I think you have a faulty lamp on the bottom, has the unit been serviced at any time? if so then return it and let them reconnect the one lamp they missed, if not then you might have one bad lamp on the bottom of the lcd these typically have 2 lamps on top and two on the bottom, if that is not the case then you might neeed to tilt the screen a little differently,
est I can do for you based on the image you posted. happy holidays
probably your screen has to replaced due to malfunction of card that drives the screen and comes with the screen. some people tried to repair some could and others could not
Testimonial: "Do you mean that the whole screen has to be replaced? "
