SOURCE: working on a MA Audio HC4002 amp......
On an amp? All the devices should be replaced at once as they can measure or look good, but still have a high resistive leakage, and if this happens to save a couple of bucks, you can blow out all the devices you just replaced. The thing with solid state devices? Most of the time you cannot look at them and see they are bad unless they had a total blowout and blew apart and put a big hole into itself and then yes that ones bad and beleive me most of the others are too. Good Luck
SOURCE: LIghtning Audio B300.4 Protect Light
protect mode should be reset if the negative of your amp is disconnected then reconnectewd. if it doesnt help, move your ground to a different location. if THIS doesnt help, consider a repair or a new amplifier.
SOURCE: Protection mode
It's normal for some amps to go into protect for a few seconds when initially powered up. If it remains in protect mode, it may have shorted output transistors. To eliminate other possible causes, read through the following troubleshooting page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
SOURCE: My dynex tv will not come on seems to be stuck in standby mode.
It sounds like the main power supply is trying to startup but failed because there is short circuits or the main power supply is bad.
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
