On the remote, press the "MENU" button to go to the "Menu" screen, select "TV Settings" with the arrow keys, and press the "OK" button. Then go to "Device Setup" and press "OK". Go to "Input Source" and press the arrow keys until "Antenna" appears, then press "OK".
Select the "Tuner" option and press "OK". You may see an option to scan channels. Select it and press "OK". The TV will scan both analog and digital channels and can take an hour to scan all. Just wait and watch the "Found channel" count. If it does not increment, your antenna may be bad or not connected correctly.
The Vizio tuner is good enough to find over 14 digital channels with a cheap $10 flat digital antenna taped to my window.
SOURCE: Dynex 32 Inch Installation Problem
Hi I Just Bought A Dynex 32 Inch HDTV. I Did A Auto Scan And It Didnt Pick Up Any Digital Channels? Am I Suppose To Have An Antenna Or Digital Box? How Do I Get Th Channels To Come In?
SOURCE: Sony bravia v series 32"
hi,
IT normally happens after factory reset is done. You need to reprogram the channels. Try the auto program (AUTO TUNING) Process.
SOURCE: can't get the tv/input button to work on dish
Hi there! This is Kimberly Escobar with Dish Network. Just ran across your post and wanted to help. In order to get the remote to possibly work the Inputs on your T.V the remote needs to be programmed to your Vizio T.V. In order to do this we have certain codes that can be integrated into the remote. Some of the codes for a Vizio T.V are 505, 671, and 627. The procedure is press and hold the clear T.V buttton located at the top of your remote until you see all the other buttons light up in red, once they are lid up enter one of your codes followed by the pound key for example: 505#. The T.V button should light up 3 times you can then try the remote to see if it works your T.V
Unfortunately we cannot promise it will completely function the T.V so it might bu that input button does not work. If you need any help please contact us directly at 1800-333-DISH.
SOURCE: can't connect vizio smart tv with belkin n750 dual band router
In your TV's menu there should be a wireless setup. You didn't supply the Model of the TV. Here's a manual for a Vizio: http://store.vizio.com/documents/downloads/hdtv/M3D650SV/1185QSG_M3D650SV_B.pdf
SOURCE: have a vizio lcd tv . can not get any channels
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
