SOURCE: LG HBM 300 Bluetooth headset
Normally the default password for headsets is 4 zero's 0000, unless you have previously set one with the phone.
SOURCE: samsung 200 bluetooth
I had the same problem. To fix this, you need to keep hold of the button when you are turning it on until the light stays on - this is pairing mode. When the light is on, search for it on your phone and pair them up.
SOURCE: Motorola bluetooth H270 solid blue light after pairing
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
