SOURCE: I Have a Nikon d80 with a sb800 speedlight
CAMERA ON P , FLASH ON TTL , AND LENSE ON F22
WAIT FOR THE RED LIGHT ON FLASH , GOOD MEMORY CARD AND IT SHOULD WORK .
BERRIE SMITH CAMERA REPAIR
[email protected]
SOURCE: HELP PLEASE! My Fuji A900 does not shoot video
possibly the ribbon has come out of it's socket. Or it is damaged.
The selector dial on the back has it's own ribbon to connect it to the main pcb.
I have spare parts off an A800 If that's any help?
[email protected]
SOURCE: When I try to set
It sounds like your TV is on a different input. If you watch your cable from an external cable box, and this box is plugged into your TV using wires that are yellow, red, and white, or red, blue, green, red and white, you're currently watching TV on a different input than the one used for the antenna. Channels in a TV are controlled by the tuner. The tuner is the silver, threaded, post on the back of a TV, DVR, converter box, or VCR, that you plug an antenna or cable wire to. The tuner contols channels while the other inputs on your TV carry a direct signal like a computer to a monitor. So when you use something other than coaxial cable to connect cable to your TV, you can't access the channel menu while on that input. To access that menu, change the TV's input or source to TV or stop when you see a channel number on the screen. You have to be on the TV or tuner input in order to access the channel menu. If you're on any other input such as, S-Video, AV1, AV2, component (Yp Br Cr), HDMI, etc. you will not be able to do a channel scan. You have to be on the right input or source.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
SOURCE: I've mislaid my manual for my Metz 54. I haven't
Not sure what S6 pro is, but if the flash doesn't fire in TTL then the flash is not support the type of TTL in the camera. I had the same problem with Nikon flashes on Nikon bodies. Perhaps you need a newer SCA adapter? Please go on http://www.metz.de/en/photo-electronics/sca-adapter/archive.html to check which adapter you need
