SOURCE: My washer won't start
did you sort you problem with your machine ? as my machine has identical fault [email protected]
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
SOURCE: Miele Dishwasher door release problem
I switched the dishwasher off at the mains and then back on again. At this point the plastic arm started making a noise like it was trying to retract so I pulled the door to help it along. The door opened and the arm fully retracted - much to my relief.
SOURCE: Miele novotronic w820
i havent changed one on this model but there useally much the same and qiute easy to do first take the back off the machine
at the lower half of the rear of the drum there is two prongs sticking out with wires on spade connectors a third earth wire in the centre remove these 3 wires they should just pull off but sometimes held on by nuts you will have to check yours then with the machine emty of water unbolt this is the element assembly is the reverse
