SOURCE: my panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
SOURCE: panasonic sa-ht540 f61 error message
If the model has a fan fitted (may have 2) that be your problem faulty fan
SOURCE: F61 code error
I had this problem! Panasonic 5CD Hi Fi. I opened the case to get a look at the circuits and noticed a covering of dust on the components. I took the hoover to it and an initial inspection could find no glaring problems, such as burnt PCB! I decided to power-up and to my joy the machine whizzed into life. Problem solved!!!!!!!! BTW, this unit is at aprox 10 years old and still goin great!
SOURCE: How to fix F61 error?
First re solder any dry joints on Transistors Q502, 504, 507, 515 & CN500, IC501. If there are no dry joins replace IC501 (STK470-0??) & maybe D501 (16.V) zener
SOURCE: Panasonic SA-AK600
F61 Error Solution for the Panasonic SC-AK600 CD Shelf System - I purchased part #C5ZAZ0000075 directly from Panasonic and had my brother-in-law un-soldier the old one out and re-soldier the new part in and the system works like a charm! No more F61 error! The part cost me about $28.00 with shipping and handling. Someone suggested this earlier in 2009 and they were right on the money. Thank you for the wonderful suggestion! Good luck!
Panasonic SC-AK600 CD Shelf System - if you have any knowledge on electonic just replace the electronic part number #C5ZAZ0000075
you can buy it directly from Panasonic,,, or if you dont have any knowledge on electronic just bring it to nearest panasonic service center.
if this help you please rate me thanks bro...
