Question about Dacor Ovens
I replaced one of the lights in my Dacor oven and then both went out. Did I do something wrong?
    Habit-Forming:
    New Friend:
  • 33 Answers
Be sure to use appliance bulbs only
Posted on Feb 02, 2019
  • Ron Sustaric
    Ron Sustaric Feb 02, 2019
    New Friend:
  • 60 Answers
Were the both the same voltage and don't touch the bulb with your fingers us clean rubber gloves
2 Suggested Answers
SOURCE:
ginko
  • 19396 Answers
SOURCE: Dacor ECS130SCH - Both oven
If you read 0.5V with light on, then there must be something wrong, this bulbs are 12VAC.
By the way, the original part Dacor OEM 86364 is still available on the Internet, and it is cheaper than 86573. Here the part:
Ebay seller, 10 bulbs for $7.
Q10T3/CL-12V $0.41 10W 12V Replacement Lamp Light Bulb IN-STOCK
If you are not sure if a bulb has blown or not, and if the filamet does not look broken you can test the bulb using your multimeter, if the bulb reads infinity (open), then the bulb has blown.
Let me know if this solves your problem, in that case please do not forget to accept the solution.
Posted on Aug 29, 2010
What does a C76 or C77 error code mean on a Dacor wall oven?
Page 9-48 in technical manual excerpts at the link below:
http://www.uncleharrywizard.com/nephewclub/WizardRange/dacor/dacor-wall-oven.pdf
It says to call for service (by a technician). (I am only reading it from the document - I am not a technician.)
It says to replace glass/touchpad assembly.
It says wrong or unrecognized diode configuration.
Apr 03, 2018 | Dacor Ovens
My Dacor oven keeps beeping and flashing PRB. How do I stop the beeping?
Most unwanted beeping on Dacor products are due to a bad touchpad... Use your model # and start looking for a replacement , by touchpad I mean a part something like this one: Dacor Touchpad 62678B
Jul 12, 2016 | Dacor Epicure 30" Double Wall Oven,...
My DACOR + ECS 130 covection oven light relay keeps clicking.....
I have the same problem and sent an e-mail to DACOR. A James Carlos responded and advised that DACOR could not provide DYI info because of liability problems, pure BS in my opinion. I've had problems with a DACOR microwave (manuf. by Sharp), my DACOR wall oven Model ECS103 and my DACOR Raised Vent system and told Mr. Carlos so. I don't know how to fix the blinking oven light other than cutting power at the circuit breaker panel or removing the two light bulbs which other have advised but suspect a new front control panel is required. If you find a fix, please advise me at bsquared37@yahoo.com. I think DACOR products are overpriced and junk.
Thanks, Bill 12/10/2009
Aug 27, 2009 | Dacor ECS130 Epicure Electric Single Oven
Dacor touchpad
HI, this is a Element relay circuit failure. this relay is a separate PCB board with attached relays.
this relay board will need to be replaced.
CLICK HERE TO ORDER
Jul 19, 2009 | Dacor ECD230 Epicure Electric Double Oven
Dacor ECPS130 fan won't shut off
Hi, Dacor has a Technical Manual that may help you with your problem. It has a ECS wall mount oven but does not list a ECPS. Is your listing of the model correct? Here is a link to download the Technical Manual. https://www.scribd.com/doc/14008662/Dacor-Technical-Manual
Hope it helps.
Mar 20, 2017 | Dacor PCS130 Preference Electric Single...
Inside oven lights won't work.
Hey,
I went to the appliance store where I purchased the oven, and they called a Dacor representative. A flat end tool was given to me to pop out the plastic covers. There are no screws to fasten the covers, so you have to use this tool - which was not put in my kit at the time. Be careful when doing this, because the plastic cover can break. You replace the bulbs by pulling out and pushing in the socket. There is no turning the bulb. Handle the bulb with a paper towel, because the oil from your hands will take life from the bulb. Very important that the oven's breaker is off before this is done. Luckily, I had a very kind clerk helping me, and she even gave me the bulbs free of charge.
I like your website, and I will use it again in the future.
Feb 08, 2008 | Dacor ECS130 Epicure Electric Single Oven
Oven light
The touch membrane is gone. You can replace it (like i did) and wait for the next thing to go wrong. Took me 3 months for the next problem, and the membrane was $300.
Dec 04, 2007 | Dacor MCS130 Millennia Electric Single...
ECS130 - Possessed Oven
The fix is replacing the mebrane panel. Recent poster advised they where able to get Dacor to send a new panel and they would install (it's not difficult). I bought one online for around $175 and installed myself. Do a search for details.
May 23, 2007 | Dacor ECS130 Epicure Electric Single Oven
Ovens Logo
Top Dacor Ovens Experts
Jaime Hernandez
Jose Pino
Paul Bade
Are you a Dacor Oven Expert? Answer questions, earn points and help others
