Garden Logo
G
Guy Galante Posted on Feb 02, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Good morning. I have a Pacific Hydrostar electric pressure washer item number 69488 and I need a detergent bottle part number 27a Can you help me Thanks Guy ([email protected])
dannydoesita
Level 3:
  • Master 778 Answers
  • Posted on Feb 09, 2019
dannydoesita
Master
Level 3:
Answers
778
Questions
Helped
226861
Points
6375
1helpful
Hi please need Help with my pacific hydrostar pressure washer model 98444 were do you drain the pump oil?
https://www.youtube.com/watch?v=XGifDw_Vs_Q
owners manual below
https://www.manualslib.com/manual/796394/Pacific-Hydrostar-98444.html?page=19#manual
https://www.youtube.com/watch?v=Zm9MV7s2EOg
If your pump has no drain plug. If like the second video seems like you could turn upside like I do my lawn mower or remove the four bolts and spin pump upside down.'
That is if your pump is like the one in the video.
May 03, 2019 • Garden
Pacific HydroStar Pressure Washer 69734. What is the secret to having the unit draw up the detergent solution?
First, I'm not a Pacific Hydrostar representative.
* Check your warranty. Call for support.
*** the following is for information only. ***
* Manual; http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/69734%20manual%20IPL.pdf
* Customer's review; https://www.youtube.com/watch?v=SQCqY1aTmI8
* Customer's start up; https://www.youtube.com/watch?v=T8fxwl06G8s
* In mosts cases of non function in the liquids is a clog (or it's turned off). Clean up all hoses and check if clear.
* Some units may require priming (check the manual)
Aloha, ukeboy57
Aug 03, 2018 • Garden
I need to change the pump on my pacific hydrostar 2800
That cannot be done over the internet, no matter what ISP you have.
Further, you need to be more-specific about exactly what you have.
Pacific Hydrostar makes both sump pumps and pressure washers with 2800 ratings (gallons per hour and PSI, respectively). So you should use the model number of your device, not what the large print on its decals say, when requesting help with them.
Pacific hydrostar 68333 1500psi pressure washer...motor keeps cutting out, but reset breaker does NOT trip.
dont know the model or if it has a pressure switch inside the box but try and remove your lance and just operate the gun... if it runs ok your last could be blocked
Pacific Hydrostar pump 2" 6.5 HP Item # 95977. I
Do you know where get a owner/repair manual for a Pacific Hydrostar portable water pump #95977?
Jul 09, 2011 • Plumbing
7helpful
Pacific Hydrostar 95618. pump oil?
Pacific Hydrostar is another pacific rim product that has no website, and no manuals online, and nobody to contact, and no parts available. These machines must be made for the throw-away user.
Pump oil comes about half way up inside pump housing > pump oil is 20 or 30 weight non-detergent oil SAE20 SAE 30
Engine oil comes half way up dip stick > engine oil 10W30
Do not turn power washer on its side or upside down when draining oil, or engine oil will go into carburetor and machine will not start
Oct 13, 2010 • Garden
No pressure with detergent bottle on
you wont get pressure with detergent bottle on.it only sprays low pressure .just take off first section of wand,and plug it in
Help! i have a pacific hydrostar 65078. Engine runs fine. Pump pressure is good with the hose off. the stream shoots across my driveway. But when i connect the hose(sears 3/8 25'' i loose all pressure.
You have to have a clogged hose gun. Try blowing it out with air. Also, Harbor Freight sells the Pacific-Hydrostar and you can buy a 2 year full warranty for around $70 bucks. A small price to pay if you use your powerwasher on a frequent basis. If anything goes wrong, regardless of what the cause, they simply replace the washer.Hope this helps.
Nov 20, 2009 • Garden
Top Electric Garden Experts
NOEL
NOEL
john h
Are you an Electric Garden Expert? Answer questions, earn points and help others
