It will ring and I can answer it with no display and cannot call out
Suggest you reset handset and register again with base.
Instructions from manual...
Resetting Handsets If you have trouble with a handset or if you want to replace one, clear the registration information from the base and the handset: 1. Press & hold END and # at the same time until you see the System Reset menu. 2.If you still have the base the handset is registered to, select Deregister HS, then select the handset you want to reset. If you don't have that base anymore, select Base Unavailable. 3. To confirm, select Yes. The handset displays Handset not registered. Registering Handsets If you see a "not registered" message on a handset, you must register it to a base before using it. 1. Place the handset in the base; the display should say Handset Registering. 2.Wait until the display says Registration Complete (about 30 seconds), then pick up the handset and press TALK/FLASH. 3.If you don't hear a dial tone or the display says Registration Failed, charge the battery completely, then try again.
