SOURCE: Westinghouse LCD tv LTV-32W4 has great sound but no picture.
Your television actually has a backlight bulb which can be replaced at our parts request email and phone number. Email address: [email protected]. (866) 839-5888
SOURCE: westinghouse LTV30w2 has blank screen and audio
What you have is a darfon V144 board (junk). it's a simple fix if you know how to use some basic tools and a soldering iron. Get an led (i used digikey's PN: L10041-ND) and solder it from pin 10 to pin 16 on the OZ960 chip on the inverter board. If you need the chip layout type "OZ960 pdf" in google. Hope this helps.
SOURCE: 32" flat screen Westinghouse TV
Hello, it sounds like you need to replace the inverter board on this unit. I would recommend opening the unit from the back cover, get the part # for the inverter board (long green board normally running accross the edge of the TV) and go to www.shopjimmy.com, they should have it in stock and if not you can try www.invertercentral.com, they should also have it.
SOURCE: Westinghouse SK 32H540S when i Turn on TV, get
The problem is cause by the transformer on LIPS inverter (Power supply + Inverter board). You could see an obvious burn on the 1 of these transformers ( There are total 3 black transformer on this board). The part number is 4302H. It is available online at http://www.lcdparts.net/TransformerDetail3D.aspx?ProductID=2775
SOURCE: My Westinghouse LTV-32w6 HD has sound but no picture
You may have problem with the T-C0N board, worst case will be the main logic board, try cooling the T-CON board with electronics freeze spray to see if the problem will go away, you can get it from Radio Shack.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
