SOURCE: 1998 Chevy Monte Carlo. Brake lights won't work.
you give some good clues. because your third brake light works but not the other two, and because you sometimes get brake lights if you have turn signals on at the same time, i would say that some wires got crossed up with your other taillights. check out the power wires back in the taillight assembly and the wires that run back to the taillights. something is mixed up back there, now you just have to find it. if all else fails after you isolate which wires are the brake light wires get some new wire, same gauge and roughly same length, remove a bit of insulation but don't cut the wire in two, and put the new wire in as an overlay. if having the new piece of wire there makes the brake light work you found the break in the wire. you can cut out the bad piece and fasten the new piece in. you can solder it if you have the equipment to do that, or you can buy some squeeze in place connectors at the car parts store. either way, good idea to tape it up when you are done. hope that helps
SOURCE: 2002 monte carlo front end vibration
Does the left front go click, click, click on tight slow turns.
SOURCE: 2004 monte carlo. turn signals dont work. the
try pressing the hazards on and off if they still don,t work replace the flasher unit. it is built into the hazard switch( all one unit ) change this and all will be good.
SOURCE: 1998 Chevrolet Monte Carlo brake lights do not
I had to replace the turn signal switch in my 1998 z34.Now everything works fine.
SOURCE: My 2002 monte carlo ss sunroof won't go all tha
Sounds like it is going off track whenever it gets to the popping sound point. Or its catching against something, Check to see if anything could be in the tracks of the sunroof. Hope this helps, James Booth. Let me know what happens
As soon as you click on the edit button, you will see a red colored icon on the installed apps.
Click on the red remove icon on the installed apps to uninstall them. Once you are done uninstalling the apps, click "Done" on the top left corner of the screen.
That's it you are done with the process of uninstalling apps in Samsung phone.
Regards
