SOURCE: I have a John Deere Ride on Toy stuck in reverse
Are the actual shifter levers not engaging or are the switches not clicking?
These Peg Perego Parts are available at http://www.shopjandl.com/, but I would check to make sure if it is the switches specifically or the levers under the shifter.
It is simple to check the shifter by taking the 2 screws out that hold the shifter in.
Hope this helps.
Let me know what you find.
SOURCE: my sons peg perego john deere jeep only sets off
I would get the Peg Perego Gator Shifter Assembly from http://www.shopjandl.com/
Make sure the wires are secure on both motors in the back.
One time I had the same problem and I had loose wires on the motor, but I ended up replacing the switch assembly later because it would only work in 1st gear.
Hope this helps
SOURCE: Peg Perego John Deere tractor 12volt will only
check all wre connections are not dirty or loose!
lift out pedal swith to check there too!
Cheeers Rob
SOURCE: John Deere tractor
Ok Simple Rule
V BELTS go in V pulleys
Flat pulleys get the back of the belt. You must take the deck off the tractor to do this properly. Look inside the hood I have seen belt diagrams there or on top of the deck.
When all else fails Go to the JD Dealer they will gladly help.
SOURCE: john deere 300 garden tractor will not go forward or backwards
Make sure the neutral lever (rod) back by the right rear tire is pushed ALL the way in.
