The drive may be damaged or corrupt, it should give you repair options
good luck
https://www.6ya.com/mr.mike
SOURCE: what does an explanation mark inside mof an upside
Tire pressure gauge. All you have to do is check the tire pressure in the driver side door jam [Its probably going to be 33 PSI]. Just inflate or deflate the tires to the proper PSI and the light should turn off after driving 5 miles or 5 minutes. Happy motoring!
SOURCE: warning light with a tire and an explanation mark
you have sensors in each tire that warns you of lower tire pressure just put some air in your tires to specs and the light should go out.
SOURCE: Yellow explanation mark warning light
Looks like traction control. If you have an owners manual they are all described in their, But on my checking and as above on anonymous it looks like traction control, turned off or if its coming on as you slide around corners it is just saying it is activating and stopping you from loosing control.
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope it helps
if you can see your usb device but its not working
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
ports(com&lpt)right click update driver if this fails to fix the problem
hope this helps you
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps you
hope this helps you
is it password protected or you just cant access it to see it
could see a yellow question mark?
fix the problem
computer and its parts hope
this helps
