Hi there, go here https://www.manualslib.com/products/Maytag-Mhwe300vf00-277610.html and look for the button lock setting. if this is not this issue please cut off the breaker or unplug the machine for 2-3 minutes and reapply power then try. there is not much you can do beside reset it and push a few buttons it might actually need repair
good luck
https://www.6ya.com/mr.mike
SOURCE: Maytag 3000 series dryer, coins stuck in dryer fin
open the top of the dryer. slide the belt down to the power unit. of course you shoudl always unplug the unit first before removing the cover. carefully lift up ont he drum and they shoudl fall out. carefull y palce the drum back and the belt. replace the cover and plug in to see if that works.
SOURCE: 1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
SOURCE: Maytag 3000 series locked close and inoperable
if there is still water in the machine then you need to drain the water.
this can be done by using a wet dry shop vac and attach it to the end of the drain hose and remove the water that way. this will normally unlock the door
also check the wiring to the drain pump this does effect the door. you may aslo try pushing the clear or cancel button for three to five seconds.
i hope this was helpful to your problem.
Testimonial: "I will have to get my hands on a wet/dry shop vac, but the super quick response is greatly appreciated. Hope it works."
SOURCE: Maytag 3000series front loader model
Being a high efficiency washer, this model uses less water. Not all the soap suds have not been rinsed away. Most likely you are using the wrong detergent. Use detergent with the he label on it.
SOURCE: I have a maytag front
press and hold the lock button down for 3 seconds and it should unlock. if it does't then the electronic control is malfunctioning.
