Question about KLH Audio Players & Recorders
I have a klh 2400 reciever and speakers work fine until i plug in my aux Y cable (trying to stream music) I get sound but barely
SOURCE:
SOURCE: connect R5100 to DVR/Monitor
use component audio to the HDTV and optical audio to your KLH reciever. The component and optical are always active at the same time. I work for TWC if you have more questions.
Posted on Aug 08, 2008
  • 4 Answers
SOURCE: klh r7000 no sound
Like I wrote, I had a similar problem with popping and then no audio for an extended period of time. I found the solution on another site, http://dexsoft.com/blog/?p=15
Apparently the solder joints are weak, and just as the blog described when I opened up the receiver I saw the same scorch marks from overheating. Just as the blog described, I added solder to each of the joints in the photo and have had no problem ever since.
I am no solder expert, this is my 2nd time, but all I did is build up each of the joints and I have been listening to music, playing movies in surround sound with no problems, no popping for the last 2 weeks.
Posted on Oct 04, 2008
SOURCE: KLH SUBWOOFER - RECEIVER-SURROUND SOUND -5 SPEAKER HOOK UP INSTRUCTIONS
Had the same problem with KLH E-10D Preamped Subwoofer. Afte brief research, I found the problem was with my Pioneer VSX-D509S reciever settings, not the subwoofer. If you have the same reciever, you can go to the pioneer website to download specific model owner's manuals.
http://www.pioneerelectronics.com/PUSA/Support/HomeEntertainment/ch.AV-Receivers.Archived?vgnextfmt=Archived
Select your Pioneer reciever model and it will give you an option to download the pdf manual. Hope this helps.
Posted on Jan 24, 2009
  • 19 Answers
SOURCE: Have new LG 42" LCD and no sound on the 5.1 Surround Sound
Try running a set of audio cables(Red/white) from your audio out jacks on the back of your TV to your reciever's audio in?
Posted on Feb 21, 2009
go to this site dexsoft.com/blog. Is under : KLH R7000 no audio repair. Problem solve
Posted on Jun 05, 2009
Klh s120eth subwoofer not producing sound.
Normaly C26 has turned bad. It's 22uF/25V and is easy to access when module is disassembled.
Dec 29, 2012 | KLH Audio Players & Recorders
I am trying to run a monitor using the Aux Send on a Mackie Board but even with the Master Aux Send turned up there is barely any sound coming out when I try to use my microphones. Also, I noticed that...
No there is no special cord. The aux you use for a monitor should be pre fader( that means the signal comes before the volume slider) turn the individual slider all the way down. Talk into the mike at the volume you would be singing at the loudest. Adjust the gain of that chanel up untill the clip light comes on. Now back it down so it dosent come on at your loudest. Now pick the aux you want to use. Turn it up 1/2 way, turn up the master aux send coresponding to the channel aux number 1/2 way you should get sound. If it's too loud turn it down if you need more turn it up. If you have any more questions, give me a call at the shop.
Vito Vacirca Jr.
Pro Line Music
490 Lincoln Highway
Fairless Hills Pa. 19030
215-736-8055
servicedepartmentprolinemusic@comcast.net
www.prolinemusic.com
Jul 15, 2011 | Mackie 1604 VLZ 3 16 channel Analog Mixer
No sound from turntable
1 ensure your reciever is also set to AUX .
2 try another AUX device such as an MP3 player or CD player and check that your Receiver AUX function is working.
2. connect your Turntable to another input such as DVD, CD, or Tape to see if it works at that position.
ensure that the correct button is selected for which ever position you use.
Nov 14, 2009 | Cars & Trucks
Add su bwoofer to KLH 200
the subwoofer i have, a polk, connects directly to the right and left speaker lines of the klh2400.
i then connect my stereo left and stereo right speakers to the subwoofer.
essentially, the subwoofer becomes a middle station between my speakers.
make sense?
Jun 06, 2009 | KLH KL2400 Tuner
Klh audio video R5100 surround sound receiver
could be 2 things....
1) The receiver could be set to feed the right speaker with more volume. Check the volume setting for each individual speaker on the receiver.
2) The cable connecting the left input from your dvd player is not connected properly or is bad. Try swapping the left and right audio input cables to see if this moves the problem to the other side. If it does - get a new cable.
May 12, 2009 | KLH R5100 Receiver
How to change speaker yamaha keybord
Simply put, the speakers can't be changed on Yamaha keyboards. If you have blown the speakers then put the sound through an amplifier or HIFI speaker system - but you must be able to have an AUX cable and AUX on the HIFI for this to work. Sometimes it can also work by use of composite cabling too, depends really on what audio equipment you have.
Apr 02, 2009 | Yamaha YPT400 61 Key Portable Keyboard...
Connect R5100 to DVR/Monitor
Apr 15, 2008 | KLH R5100 Receiver
KLH R7000 Component Video Problems
I have lost my remote and instruction book where? do is it worth it replace
Mar 07, 2008 | KLH R7000 Receiver
My computers sound not working.
try new sound drivers for your model pc ok
Feb 07, 2008 | Dell A215 Computer Speakers
Subwoofer VERY weak
According to the KLH manual for the 9906 "6 pack" with the BassBite sub... it says "if your sub is connected via the speaker - level terminals, your reciever must be set for "NO" subwoofer - even though you are using one. VErify proper polarity on your speaker connection wires. (red or gold to +, black or silver to -). Depending on how you have your woofer connected to the reciever, if connected to a reciever without a subwoofer out then set your reciever for LARGE speakers and turn the subwoofer setting "OFF". Failure to do so will result in little to no bass. If you do have a subwoofer out from your reciever adjust your speaker size setting to small or large speakers as appropriate. Set the recievers sub output to ON. Connecting small speakers to a reciever set for LArge speakers can result in damage to small speakers.
Hope this helps.
Jan 14, 2007 | KLH HTA-4100 System
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
