Question edited for clarity. Full 'make model (what it is)'.
Did you put batteries in both units and in the right order, sensor first?
Step 1: Insert 2 fresh AA, batteries into the TX29U-IT sensor according to the polarity marked in the battery compartment.
Step 2: Insert 2 fresh AAA, Alkaline batteries into the wireless thermometer according to the polarity markings. Step 3: After 5 minutes place sensor outside in a shaded location.
https://www.lacrossetechnology.com/products/WS-9160U-IT#support
Retired unit so no further warranty or parts.
You can still get one on Amazon
La Crosse Technology WS-9160U-IT Digital Thermometer ...
Amazon.ca
https://www.amazon.ca > Technology-WS-9160U-Digita...
Digital thermometer with wireless remote and clock; Remote sensor transmits from up to 330 feet; records daily high and low temperatures; Receives weather ...
Rating: 4.4 · 7,970 reviews · $31.50 · In stock
SOURCE: changed batteries
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
SOURCE: The outside temp sender won't work. We put new
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
SOURCE: my skyscan model 87800 will not show outside temp.
Look in the manual, There should be a section on remote sensors, they usualy have a "sync" button on them. and hit main unit first then remote.
SOURCE: Model-WS-7013U...changed all batt. inserted in
I have the 7013, where do I put the temp transmitter, I have never use this on, I am replaceing an old one that has awire from out side that plug into transmitter, your mode dosn't. Placing the transmitter out sideside? Help
SOURCE: It simply stopped working as
Welcome to Fixya!
The charging port is at the back of your Garmin device. It is also the USB port. See image below.
You will need a car charger to be able to charge it on your car, or use it while charging. See the image below.
If you do not have one, you can get it from Amazon.com for a fairly good price. Just click the link below.
http://astore.amazon.com/securetransaction-20/detail/B004AL7B7K
Thank you for usng Fixya, have a great day.
J
as247
