SOURCE: majestic filter queen canister vacuum cleaner
It will work again if you press the reset button which is the little (really little) button right on the back of the part that suctions.
SOURCE: Need Filter Queen Majestic Owners Manual
I downloaded and printed a Filter Queen Owners Manual from the Filter Queen.Com website. It was hard to locate on their website, but I printed it free.
SOURCE: I was given a filter queen majestic limited
This is a very straight forward good quality vac, with excellent filtration.
The cannister has two large clamps to release the motor from the dust chamber. Depending onb the age you may have an LED which comes on when it is time to empty the vac. The cleanest way to empty is to leave the paper cone over the dirt and carefully tip all into a garbage bag sitting on the floor.
You should replace the paper cone with a genuine fresh one each time you empty the container. In addition there is a paper disc inside the motor housing which you will access by removing the flat screw at the bottom of the plastic grille cone.
Testimonial: "Thank you for the info. I have already changed the cone filter but didn't know about the other one."
