Question about HP Office Equipment & Supplies
Hp laser jet pro mfp m476 had a rear door paper jam Paper cleared (intact), but paper jam message still occurring.
I've gone through all the basic HP troubleshooting to no avail.
SOURCE: Cant figure out how to open Tray 1 to clear paper jam
Leave Tray1 closed. Remove tray 2. Push down on green arrows visible after removing Tray 2. You should see the jammed paper on the plastic tray which becomes accessible after pushing down on the green arrows.
Posted on Jul 17, 2009
SOURCE: HP laser jet 3055 document feeder jam
document feeder jam
Posted on Jul 27, 2009
e-ware
  • 776 Answers
SOURCE: HP Laser Jet 1320. Orange light
The Amber light is designated as the "Ink Error" light. With regards to a Hewlett Packard printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
If I have helped please rate my post...I will always do my best to help
Posted on Sep 11, 2009
SOURCE: Paper jam message on HP C4599 when there is no jam
I had the same problem. I called HP and went through the steps they had asked me to go through to fix it. It took about an hour. Nothing worked. They offered me a replacement. I said no, and they offered me a $150 gift card for Staples.
Posted on Sep 16, 2009
  • 224 Answers
SOURCE: HP Laserjet 4345 mfp paper jam.
recycle the power to reset
Posted on Mar 31, 2010
ERROR MESSAGES ON HP LASER JET 1536DNF MFP jam in cartridge - there is no jam
Check to see if the paper is feeding, should be feed some what into machine, if not paper is not getting to cartridge and showing a jam... some times clean wheels with water or windex
Mar 28, 2017 | HP Office Equipment & Supplies
Hp LaserJet Pro 400 paper jam in cartridge area
Clean all of the rubber feeders with alcohol/rubber restorer in the paper path of printer.
Sep 14, 2016 | HP Laserjet Pro 400 Mfp M425dn...
My laserjet pro 400 color mpf m475dn printer is indicating " paper jam...open back door to clear jam," please describe how i will go about this process.
There is an access door in the back of the printer. Open the door and you should see jammed paper. If not then you have a faulty sensor or switch.
Mar 20, 2014 | HP LASERJET PRO 400 COLOR MFP M475DN
HP LASERJET 100 COLOR MFP M175a PAPER JAM
I suggest you some points like clear the dust in the printer, proper set paper in paper place, adjust the paper line etc..
If More Support visit this link. I hope solved you problem..
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02622145&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=5076465
Jan 15, 2014 | HP LaserJet Pro 100 color MFP M175A Laser...
Paper jams at toner cartridge, printer service maintenance kit installed
Paper Jam clearing: copy and paste the link in your web browser...I used to work with these printer's..when they work great, when they don't, not so great..
https://www.manualslib.com/manual/949165/Hp-Laserjet-5000.html?page=84
Clearing Paper Jams If the printer's control panel displays a paper jam message, look for paper in the locations indicated in Figure 22, then see the procedure for clearing the paper jam. You might need to look for paper in other locations than indicated in the paper jam message. If the location of the paper jam is not obvious, look first in the top cover area.When clearing paper jams, be very careful not to tear the paper. If a small piece of paper is left in the printer, it could cause additional jams. If paper jams are a recurring problem, see page 78.(A paper jam message might also display if the rear door is open.)
The top cover of the printer must be opened and then closed to clear a paper jam message.Paper jams can occur at the following locations:Output areas(top and rear)Go to page 75.
Loose toner might remain in the printer after a paper jam, but thetoner should clear after a few sheets are printed.
Jan 31, 2018 | HP LaserJet 5000n Printer
Jam paper
Hi
Please follow the below link and it might help you getting started again with the printer.
http://www.manualsprinter.com/manuals/hp/HP_LaserJet_Pro_M1217nfw.pdf
Oct 06, 2012 | HEWLETT PACKARD - LASER JETS Laserjet Pro...
My brand new hp 8500 wireless office ink jet printer say open the carriage access door clear the jam. We took the small 2 ink cartiages out and put them in again and this keeps come up.What do we do now?...
Why are you taking out the ink cartridges??
The message says to open the carriage access door and clear the jam. The printer thinks that paper is stuck in the paper path, see if you can find it. I believe that there is also a rear door on that printer, remove it and look inside.
Sep 10, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Clear Paper Jam, then Press OK
Have you checked the access door in the rear of the machine?
Jan 05, 2009 | HP OfficeJet 7410 All-In-One InkJet...
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Clearing paper jam
Solution Use the following instructions to clear a paper jam from the HP All-in-One.
  1. Press in the tab on the rear clean-out door to remove the door. CAUTION: Clearing a paper jam from the top or front of the HP All-in-One can damage the print mechanism. Whenever possible, access and clear paper jams through the rear clean-out door. Figure 1: Pressing the tab and opening the rear clean-out door c00444711.gif
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the HP All-in-One. If you do not remove all the pieces of paper from the HP All-in-One, more paper jams are might occur.
  3. Replace the rear clean-out door and gently push it forward until it snaps into place.
  4. On the HP All-in-One control panel, press OK to continue the current job. NOTE: If the paper is still jammed, see the onscreen Troubleshooting Help that came with the HP Image Zone software.
  5. If the jam occurs again, check to make sure the paper type in the printer matches the paper type set in the printer driver properties
May 09, 2008 | HP Photosmart 2575 All-In-One InkJet...
Clive
Clive
