Microwave Ovens Logo
C
Cynthia Hoot Posted on Feb 01, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our microwave now does a constant humming noise when it is plugged into power.
William Miller
Level 3:
  • Microwave Ovens Master 9,179 Answers
  • Posted on Feb 04, 2019
William Miller
Level 3:
Answers
9179
Questions
Helped
4479475
Points
21747
It probably has a shorted cook relay and is microwaving whenever the door is shut. You should unplug it until it is fixed.
I can normally repair this for $54.95, which includes insured return shipping.
Feel free to contact me via http://www.microwavecontrol.com
steve-o steve-o
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Feb 01, 2019
steve-o steve-o
Contributor
Level 1:
New Friend:
Answers
23
Questions
Helped
5041
Points
57
Time for a new microwave! Service fees start at $50 just to look at it, not including repair parts. Sounds like the power supply is dying, and would cost at least $50. So go find a brand new $100 microwave, and save yourself the time!
3 Related Answers
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Jan 20, 2010
SOURCE: Magnatron suddenly making more noise. Much louder
Often over the years the Transformer laminations can loosen, from the on/off rising and collapsing magnetic fields, and then they sorta hum louder. I suspect this is what is going on. Shouldn't be too much of a worry.. keep an eye on it tho.
Testimonial: "Thanks. Should I replace the magnatron?"
Anonymous
  • 43501 Answers
  • Posted on Feb 14, 2011
SOURCE: My microwave is making a constant loud noise
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Anonymous
  • 389 Answers
  • Posted on Nov 07, 2011
SOURCE: Our KitchenAid microwave works well, heats food,
hi it could be a bad neutral connection on your plug or inside on your high voltage transformer check the plug for burning and try plugging it in a different socket
Microwave is making a noise
If your microwave is making an unusual or loud humming noise, you may have a problem with the magnetron. This component is part of the high voltage circuit and provides the microwaves that generate the heat. If the magnetron is defective, it may cause a loud humming or buzzing noise.
https://www.fix.com/repair/appliance/microwave/unusual-noise/
Microwave makes sound like something moving inside
follow this steps and use the VOM , and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
2helpful
Microwave buzzes when off
This is the power transformer humming, sometimes when transformers get older you get vibrations in the windings due to magnetic fields generated within the transformer which causes the humming noise, It's more annoying than anything and won't affect the operation of the microwave.
My microwave makes a loud humming noise when it is turned on.
May as well use the microwave as is until it terminates naturally. All microwave ovens buzz, that nothing unusual, but although you can replace a Magnetron, the cost is unusually high. By the time you take the oven down, open the case and fuss around, perhaps not making things any better; the fact is; a new replacement with a warranty is just over $100. Why bother?
Our KitchenAid microwave works well, heats food, etc., but makes a constant loud and annoying humming noise (close in frequency and tone to the hum of cold fluorescent tubes) even when not in use. When...
2helpful
Contant humming noise, even when not in use have to unplug in order to stop the sound.
The constant humming noise you hear when the microwave is plugged-in but not running is caused by the Low Voltage Transformer, which is located inside the back wall of the outer cabinet on the left side. If the microwave is working properly otherwise, there is no hazard, just the annoying noise.
To access the transformer, the microwave must be taken down and the outer cover removed. The transformer is held to the back wall of the cabinet with four screws, and there are two sets of leads with pull-apart connectors. The noise is the result of 60hz vibration being transmitted to the sheet metal from the transformer which may not have been sufficiently "potted" or otherwise mechanically isolated when manufactured. You can either replace the transformer or try wedging some thin rubber or other material between the transformer and the sheet metal to quiet the noise. Just be careful to not damage the windings!
1helpful
Constant humming sound
the most common problem with ALL microwaves is the magnatron
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
