Medical Logo
Evelien Van Amerongen Posted on Feb 01, 2019
Error Code 8 Enigma Autoclave How to fix it - Medical
Dianne Barrett
Level 1:
Habit-Forming:
New Friend:
  • Contributor 21 Answers
  • Posted on Mar 09, 2019
Dianne Barrett
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
21
Questions
Helped
6071
Points
75
1 Related Answer
t0ny_pars0ns
Tony Parsons
  • 6405 Answers
  • Posted on Aug 11, 2016
SOURCE: my enigma 8 autoclave is showing an error code of E21 and this does not appear n my user manual...help
This really comes under the category of laboratory equipment, not digital cameras, I'm afraid.
Enigma 8 Autoclave. Why does it display "Error code E13"?
hi, hopefully this will point you in the right direction.
https://excelhealthcare.co.uk/faqs/
Regards
Rob
1helpful
I have an Enigma 12 autoclave and it keep coming up with fault code E9 what does this mean
On some error 9 is "Time Error" .. the real time clock inside has failed. Normally just a small battery needs replacing but it is a technician job as the machine needs to be opened.
My enigma autoclave isn't starting. There is no error message on the screen. It just beeps 3 times and does nothing?
I know nothing about Enigma but this is typical of PC problems with memory. If there is a Keyboard, try getting into Bios by restarting and pressing F2 and Del keys alternately on turn on. This gets you into most computer Bios. When there, look for Memory/RAM to see if it is seeing any. Try "Reset to defaults" as a last resort.
Try to get the manual and look for "Trouble Shooting" section. If it has info on memory installation (for example, adding or replacing, read carefully.
If you have a techie guy there, think about opening up the Enigma to get to the main board (mother board) and removing the RAM module(s). If you can have them tested, do so. If not, clean them with a dry clean toothbrush, blow out(or vac) the main board socket the RAM came out of (be sure Enigma is plugged in and off and not too much vacuuming as it builds up static). And if there are more than one RAM, plug in only 1 or reverse the slots or use other slots if there are any. Try all combinations. Power off between each removal/insertion. Be careful and gentile but firm. Be careful of static electricity. Any little "Snap" you hear from touching some thing is a hazard to electronics, so keep in touch with the machine to stay grounded. Hold the RAM, use that hand to touch the Enigma 1st without touching the RAM to the Enigma and then proceed. That grounds you and by default, the RAM safely. Peep the Enigma plugged in but turned off except when testing.
My enigma 8 autoclave is showing an error code of E21 and this does not appear n my user manual...help
Aug 10, 2016 • Cameras
Short beeping with no error code
...no informative error? bacteriological filter? time for maintenance?
Enigma 8 autoclave error code E13
The E13 error code on an Enigma 8 autoclave typically indicates a problem with the vacuum system. This error code is indicating that the vacuum is not reaching the proper level during the sterilization cycle.
Here are a few things you can check to fix the E13 error code:
  1. Check the vacuum pump: Make sure that the vacuum pump is functioning properly and that it is not blocked or clogged.
  2. Check the air filter: Make sure that the air filter is clean and not clogged. A clogged air filter can prevent the vacuum pump from functioning properly.
  3. Check the vacuum hose: Make sure that the vacuum hose is not damaged or disconnected.
  4. Check the door gasket: Make sure that the door gasket is not damaged or leaking. A damaged or leaking door gasket can prevent the vacuum from reaching the proper level.
  5. Check the control board: Make sure that the control board is not damaged or malfunctioning.
  6. Check the water level: Make sure that the water level is at the correct level in the autoclave chamber.
Top Medical Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Medical Expert? Answer questions, earn points and help others
