Hello, Mary -
Are you asking about a Pinehurst model crib made by Babi Italia and imported from China by LaJobi? If so . . .
That model of crib was recalled by the US Consumer Product Safety Commission in 2009. Read the information here:
https://cpsc.gov/Recalls/2009/lajobi-recalls-babi-italia-pinehurst-and-bonavita-hudson-drop-side-cribs-risk-of
By the way,
(Quote)
. . . LaJobi is no longer in business and repair kits are no longer available for recalled LaJobi products. Any LaJobi-made products that have been recalled should be discarded or destroyed.
(End quote)
Source:
https://onsafety.cpsc.gov/blog/2015/01/26/check-your-homes-for-recalled-lajobi-cribs-and-glider-rockers/
Someone who is "crafty" could choose to re-purpose the crib into something else, like a bench.
Best wishes.
SOURCE: missing screws
I had a similar issue and found the solution at http://productsamerica.com/page29.html I hope this is helpful to you and anyone else with similar issues.
Eric L.
SOURCE: converting it into a full size bed
Here is the manual: http://www.deltachildrensproducts.com/product_detail.asp?product=100026&dept_id=100027
The product manual will tell you how to convert it to a toddler bed, and here is the contact information to get to customer service to ask where you can get the parts:
http://www.deltachildrensproducts.com/customer_service.asp
SOURCE: conversion instructions from crib to full size bed
check this website. www.babysdream.com/Service/AssembIns/pdf/Convertible%20Generation%20Next%20Crib%20Instruction I needed the instruction to convert my daughters bed and was looking for some help and notice your question.
Good Luck
SOURCE: lost screws for baby bed do not know what size it takes
You will more than likely need a 1/4-20 screw/bolt, or a 7mm. You can find these at any Lowe's store. They are in the "specialty" drawer section of hardware in the N drawers.
SOURCE: Unique Oak Treasures Crib - Full Bed Bassett Model 5542-0521
We have this crib as well. We bought it from Babys R' Us in 2005.
We also purchased the rails to convert it to a full sized bed. It did not come with instructions but I can explain to you how to put it together.
The rail conversion set should come with 2 pieces of wood that act as the bed frame. You do not need to purchase the extended frame. The set should also come with 4 long screws, the hex tool to tighten it and 4 metal pieces. You might also have some wood nail cover plugs.
Once you've taken apart your crib, the only pieces that you will need are the 2 longer pieces of the crib...the headboard and the footboard. The 2 shorter side pieces which served as a headboard and footboard as a crib and the metal grate to hold up the mattress can be put into storage.
On the sides of each of the new wood rails, you will see a circle indent on each end with a hole. You will insert one of the long screws into each and then insert it into the head board. You must use the special tool to screw/ tighten it in. The metal flat pieces can be inserted into it the circle befor eyou are done tightning so that it does not strip or damage the end of the circle. You do this with the other rail on the other end and then add the footboard using the same process. If you would like, I can send you a copy of what this looks like close up. ( the cricle indent with screws. The bed is extremely strong. We've all napt in it as a family along with our 2 large dogs. I highly recommend ordering the extra long/ tall bed rails from OneStepAhead for security because my son has rolled out of the bed and it is super tall!
http://www.onestepahead.com/catalog/product.jsp?productId=534602&parentCategoryId=85183&categoryId=85216&subCategoryId=86203
Converting a Simplicity Crib into a Toddler Bed:
Please note, Simplicity has gone out of business and the Simplicity Cribs should NOT be used as cribs. They were sold at Walmart, Target and BabiesRUs. The word on the street is that Walmart is the easiest to deal with when it comes to returning them. Those who wish to return Simplicity cribs don't need a receipt, they can just take them to Walmart for store credit. BabiesRUs was apparently giving about $65 while Walmart was closer to $190. Again, this is just what I have heard from others.
You can find the specific information on the Simplicity recall here.
If you do want to use your Simplicity crib as a Toddler Bed, I have not read any warnings against this. Again, I might just take it to Walmart anyway and get a store credit and perhaps buy a new convertible crib. You can get some great ones on Amazon for around $150 with delivery included.
I would pack it up, take it in for store credit, and get a new crib!
You can get some great deals these days on cribs, there's a great one on Amazon for $150 with free shipping so it's kind of a no-brainer.
As I have heard, Walmart will take it back, no questions asked and no receipt necessary and you can get a brand new one with brand new parts, brand new instructions and no recalls or risks!
Good Luck.
Here's one of my favorites:
Graco Sarah Classic 4-in-1 convertible bed
If you still want to convert it, here is what you need to do:
1. Remove the front panel of the Simplicity crib. Use an Allen wrench and 45mm bolts (there should be extras underneath the crib, along with an Allen wrench, but if there aren't then you can pick some up at your local hardware store.)
2. Check the mattress support. It needs to be in the lowest position available, which will allow the toddler to get in and out of bed easily. It is also the only position that will make the rails line up properly with the pre-drilled bolt holes. To lower the mattress, unscrew the four bolts from the four corners of the mattress support and slide the support down. The holes for the lowest setting are just about the bottom wood panels. Use your Allen wrench to reattach the mattress support with the same bolts you pulled out when the mattress was in the higher position.
3. Attach the toddler bed rails to the crib frame. Use two 38mm Allen bolts on each rail. There are pre-drilled holes in both the rail and the crib frame. Line up the holes and then loosely screw the bolts into place. The bottom of each rail has a metal L-shaped hook. This will slide under the mattress support. Use a 19mm Allen bolt to attach this piece to the mattress support. When everything is lined up and screwed in loosely, go back and tighten each bolt. Repeat on the other side.
4. Check the entire crib frame for loose bolts. Use the Allen wrench to tighten all the screws. Toddlers can be rough on their beds, so it is important to make sure the bed is safe. You should recheck for loose bolts often. Jumping and climbing on the bed can easily loosen the bolts and screws.
5. Don't forget to hang onto the front panel and store it carefully, you will need it later to convert the bed into a full sized bed.
