SOURCE: Purchasing an internal circuit board part for a sharp LC 20S1E LCD TV
send me the model and serial number and i will be able to advise you
Lou Margo
Allied Electronics
[email protected]
SOURCE: SHARP AQUOS LC-26P70E - Clock
Most TV's don't change with daylight savings time, since they do not operate with a date, just time. You will need to change it via the remote.
Good luck
SOURCE: I need to find 2 capacitors for a sharp lc-26ad22u
Those numbers are not the right ones to find on capacitors.
If they are capacitors, they must have markings such as (for example) '47uFd' (value of capacitance) and '63VDC' with polarity signs of + or - near the two leads.
Additionally, there will be reference numbers close to the parts such as; 'C134'
Those devices which are heat-damaged could be chokes. They are inductors and will show copper windings if the insulation is removed.
If they are, look for their reference designators starting with 'L'.
If they are chokes, they may be of an odd value since these are not nearly as standardized in value as capacitors are.
The likelihood of scoring a schematic for your set isn't good; the mfrs. really aren't interested in making your TV whole again, they want you to buy a new.
If you can determine exactly what it is that has failed (I don't think those two parts are all that has died), check Mouser Electronics which appeals to small orders (they like big ones too); they have no minimums and charge actual shipping cost.
Mouser
Testimonial: "This was very informational.. Thanks!!"
SOURCE: sharp Lc-26sb24u white screen with sound
You will get a white screen when you unplug the t-con from the main board. Doing so removes power to the LCD panel. Verify that all of your voltages from the power supply are correct. If they are, I'd look at the t-con board. It sounds like there is a problem with the t-con that is pulling down the main board.
SOURCE: Sharp Aquos LC-C3237U no picture backlight OK green light on
check if their is a signal on voltages around 3.3v at the inverter board if none their is a problem in the board which is in the processor.
