Question about Stoves Ovens
How do I replace the bulb in my Stoves DF600 Dom Oven?
5 Suggested Answers
SOURCE:
  • 250 Answers
SOURCE: The bulbs are gone in my main fan oven.How do I
The lenses have to be removed to gain access to the bulbs. If you look carefully at the lense, the edge immediately in front of you will have a small lip that you can get a screwdriver blade under. do so and twist the blade carefully and the lense should just spring clear. Note that the lenses have cut outs on them to ensure clearance on the bulb, so replace them round the right way.
Oven bulbs are all the same quality, so as long as you buy an oven bulb and it is the same physical size and fitting (BC or SES), you should be ok.
Posted on Feb 27, 2010
Testimonial: "Thanks for that we thought we would have to pull the oven out to get access.You have saved us a lot of work"
  • 250 Answers
SOURCE: my stoves oven is burning my kitchen cupboards
If you could provide some more information, then I may be able to help. What part of the oven is causing the problem, i.e. top or bottom door. If the doors don't shut properly then this may cause the hot air to escape. If it is one of the doors, is it sitting square in the frame?
SOURCE: How do I replace bulb in oven? Stoves el716 what is bulb part order number?
you can remove the bulb first then go to the local pound shop or a hardware shop or even morrisons or tesco the buld will be a standard screw in but has to be an oven buld not a normal one ive found these bulbs in the local shops easily do not use any unhardened buld for the oven type i replaced one the other day as usual i got a pack of two from the local hardware guy for a couple of quid
Posted on Oct 18, 2014
stevecomics
  • 405 Answers
SOURCE: how to remove broken-off metal part of oven bulb in Stoves 900EF oven.
SPRAY IN PRODUCT LIKE NUT BUSTER, OR PENETRATING SOLVENT WD40. WITH SMALL SCREWDRIVER GIVE A QUICK TAP WITH HAMMER. IT SHOULD LOOSEN UP JUST ENOUGH GRAB WITH A NEEDLE NOSE PLYERS AND TURN LEFTY LOOSY /RIGHTY TIGHTY. GO IN CORRECT DIRECTION!!
Posted on Jan 05, 2015
How do I replace a blown buld in the main oven
In most ovens, move the metal bracket to one side. the glass dome cover should fall out. Unscrew the old bulb. Screw in the new bulb. Place the glass dome cover back over the bulb. Move the metal bracket to hold on the glass dome cover. Easy job to do.
Aug 23, 2015 | Stoves Premier 720EMa Electric Double Oven
How to remove broken-off metal part of oven bulb in Stoves 900EF oven.
Jan 05, 2015 | Stoves Ovens
Oct 18, 2014 | Ovens
Changing the light bulb in a stoves df 600 si oven
STOVES n600 is a squair glass window which prizes our from the bottom. It looks simetrical but only goes back in one way up
Oct 08, 2012 | New World Ovens
How to change oven lamps on Stoves 600EF oven
Well if it is the same as the 720, you will find a small recess in the leading edge of the glass lens/cover. Using a blunt screwdriver, insert it in the slot and twist it. The lens should gradually come away from the side of the oven. DO NOT attempt to do this if the oven has been in use as the lenses will become too hot to handle. Put a cloth on the bottom of the oven to catch the lens as it falls to protect it. Note that there may be a cut out on the inside of the lens to go over the edge of the bulb/bulb holder, so don't try to put the lense back round the wrong way.
Nov 08, 2011 | Stoves 720EF Electric Double Oven
The bulbs are gone in my main fan oven.How do I remove the bulbs to replace them and where do I buy them? STOVES 720EF.
Feb 24, 2010 | Stoves 720EF Electric Double Oven
How do i replace the bulbs inside the ovens
Feb 07, 2010 | Stoves 720EF Electric Double Oven
Need to replace grille lamps
When you look at the glass lamp covers (lenses), you will see a little raised section either at the front or back of the lense, depending how the lense was replaced previously. You need to put the largest screwdriver blade you can under the lip and turn it slightly. The cover should move and then ease the screwdriver round the lense until the lense comes clear.
Note. Cooking gunge may may this action difficult as it will cause the lense to stick and also when you replace the lense, you will see on the inside of it there is a moulding cut away to clear the bulb. Make sure when the lense is replaced, the recess is positioned so that it clears the bulb. Whilst you have the lenses out, use the Lakeland brush on oven cleaner to give them a good clean. The end result makes a difference!
Sep 30, 2009 | Stoves 720EF Electric Double Oven
How to fit oven bulb
You should have a glass cover over the bulb itself. It may either screw on or it may have 2 or 3 screws at the base of the glass to take out. Then you should be able to unscrew the bulb as you would any other light bulb in your house. You will want to replace it with another appliance bulb 40 watt. If you have another type bulb or set up in your oven let me know and we will work through it.
Feb 11, 2009 | Stoves Ovens
Ovens Logo
41 people viewed this question
Top Stoves Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Anthony Ward
Anthony Ward
Are you a Stoves Oven Expert? Answer questions, earn points and help others
