SOURCE: Motorola E815 alarm full
At the alarm screen, highlight one of the alarms, then press the main menu button, several choices, including a delete option will be given. There is even a delete all option
SOURCE: Smart set alarm clock - resetting instruction
First, make sure the time is set correctly – Eastern Standard Time (EST) is the default
Press the Alarm Mode button – it has options for Weekend, meaning Sat and Sun only; Weekdays (Mon-Fri), and Everyday
While holding either the ALM 1 or ALM 2 button, press up or down to set the correct wake-up time
Release ALM 1 (or 2) when you are finished
Here is a link to the manual:
http://www.emersonelectronics.ca/emerson/en/product/view/17796
-Tha Mp3 Doctor
SOURCE: Can't set the clock
Ensure the radio/AUX/Ipod is off (hold down the power button)
Press & hold MODE until 12:H flashed. Use the TUNE/SKIP buttons to make your selection
Press MODE again to see the hours flash and again use the TUNE/SKIP buttons to set the hour
Press MODE again to see the minutes flash and use the TUNE/SKIP buttons to set the minutes.
Press MODE again and you are finished.
To set the alarm: Press and hold the ALARM button until the time flashes and then use the TUNE/SKIP buttons to adjust.
SOURCE: Don't know how to set alarm clock or timer - have set clock OK
To set the Time all you have to do is hold memo/c.adj while on standby, the screen will flash 24hr if you press tune it will flash 12hr pick weather you want 12hr or 24hr and then press memo/c.adj to set the hours press tune then hold memo/c.adj to get to the minutes and then press tune to get the minutes set
