Question about HP Office Equipment & Supplies
My printer hp Laserjet M1132 prints ok but for every page an extra paper is pulled and the second paper stops hALF wAY causing paper jam. how to troubleshoot
  • 38 Answers
Please check pick up solenoide, maybe do?a have the spring
Posted on Feb 01, 2019
  • 54 Answers
SOURCE: My HP Laserjet 1000 printer
Cleaned the paper pickup unit gear & sensor, your problem will solve.
Thanks.
Posted on Mar 21, 2008
pagebor
  • 2785 Answers
SOURCE: Paper feed accepts paper but
your printer needs servicing
Posted on Apr 23, 2008
  • 3422 Answers
SOURCE: hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Posted on Jun 18, 2008
madguy1089
  • 21 Answers
SOURCE: When a page prints it only goes half ways and then stops and the printer says paper jam
Typically what I have seen with these printers if they do that it is because there is something blocking the path of the paper. What you can do if you are comfortable!!
Unplug the printer and lift the printer and and give it a good shake and what ever is blocking the paper will fall out if not it may loosen it enough so that when put the printer down and take a flash light and shine it down the paper feed area you will be able to see what is there and then pull it out with either a pair of needle noose pliers or your hands.
Also if you have a warranty on the printer you can just call Lexmark and they will either walk you through the same process or they will send you a new printer.
Posted on Jun 09, 2009
  • 7 Answers
SOURCE: my hp laserjet 1150 series stops printing after a paper jam
you probably have a piece of paper inside printer or you have damage a paper sensor path while removing jammed paper.
Posted on Jun 22, 2009
Error E0 on laserjet m1132 mfp how to clear it
Hi, the error E0 is for a paper jam, please make sure your laserjet M1132 paper tray is not to full. You can also do a power reset by..... 1) disconnecting the power cable from the back of the printer........ 2) disconnect the power cable from the wall outlet. 3) Wait up to 10 seconds and reconnect the power cable back to the wall outlet first, followed by the back of the printer. 4) Turn On the printer again.
Connect your printer directly to a wall outlet. (don't use a power hub or a surge protector)
??Here is a screen grab from the manual. If you need the who manual as PDF replay. Or if you have it, please read pages 189-210+.
Nov 22, 2016 | HP LASERJET PRO M1132 MFP
Tip
HP LaserJet LJ 4350 locks up when duplexing
Symptom: Your LaserJet 4350 prints just fine until you try to print a double-sided page. Then you see the page start to exit, pull back in, then stop. The Data light continues flashing green, and the display reads, "Processing..." There is no error indication, but the machine won't print the second side and continues to hold the half-printed paper in the duplexer. If you open the top cover and close it again, the printer will eject the page, then try to print the whole thing again, unless you're quick enough to cancel the job first.
Cause: The printer is expecting a different sized paper than what it's running. Often it's not the menu settings, but a little lever in the paper tray itself. Pull out the paper tray you're trying to print from and look for a little blue lever on top of its right-hand side. The lever is labeled "Standard/Custom." Flip it to Standard (parallel to the tray side) and your problem should go away.
on Mar 17, 2010 | HP LaserJet 4350dtn Printer
Black line coming while printing on hp m5025mfp
the problem is in fuser or in toner cartidge.
print a page when the printer start to pull the paper more than a half page stop the printing by open the door
remove the toner and look the paper
if you see the line the problem is from toner replace toner cartidge if you see the image ok means the problem begins when the paper go into the fuser so replace fuser.
Feb 20, 2014 | HP LaserJet M5025 MFP Printer
Hp laserjet 4200 will print a 50 page paper path test, print an extra page and then jam.
The paper feed solenoid is sticking. There is a foam material that deteriates over time and becomes sticky. I remove what's left and put masking tape in its place.
Oct 03, 2012 | HP LaserJet 4200 Printer
LOCATION OF PRINTER SENSOR
Jams
Clearing jams
CAUTION Do not use sharp objects, such as tweezers or needle nose pliers, to remove jams.
Damage caused by sharp objects will not be covered by the warranty.
CAUTION Always pull jammed media in the direction it would travel through the paper path.
Do not pull jammed media against the direction of travel through the paper path to avoid damage
to the printer.
To prevent damage to the printer when clearing jams, including jams in the output bin, always open the
print-cartridge door and remove the print cartridge. Keep the door open and the cartridge out until the
jam has been cleared. Opening the print-cartridge door and removing the print cartridge relieves tension
on the printer rollers, which prevents damage to the printer and makes the removal of jammed pages
easier.
Occasionally, media becomes jammed during a print job. You are notified of a media jam by an error
from the software and the printer control panel lights. See Control-panel lights (HP LaserJet 1010 series
printers) on page 102 or Control-panel lights (HP LaserJet 1020 printer) on page 106.
The following are some of the causes of media jams:
The input trays are loaded improperly or are too full. See Loading media on page 25.
NOTE When you add new media, always remove all of the media from the input tray and
straighten the stack of new media. This helps prevent multiple sheets of media from feeding
through the printer at one time, reducing media jams.
The media does not meet HP specifications. See Media specifications on page 21.
Typical media jam locations
Print cartridge area: See Removing a jammed page on page 43.
Input tray area: If the page is still sticking out of the input tray, gently try to remove it from the input
tray without tearing the page. If you feel resistance, see Removing a jammed page on page 43.
Output path: If the page is sticking out of the output bin, see Removing a jammed page
NOTE There might be loose toner in the printer after a media jam. This toner clears up after
a few sheets are printed.
Use the procedures in this section to remove a jam.
CAUTION Media jams might result in loose toner on the page. If you get any toner on your
clothes, wash them in cold water. Hot water will permanently set the toner into the fabric.
Partshere Troubleshooting
CAUTION To prevent damage to the printer when clearing jams, including jams in the output
bin, always open the print cartridge door and remove the print cartridge.
To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print
cartridge with a sheet of paper.
NOTE The following illustrations show the HP LaserJet 1020 printer. The same procedure is
used to remove a jam in the HP LaserJet 1010 series printers.
Open the print cartridge door, and remove the print cartridge.
Grasp the middle edge of the side of the media that is most visible, and carefully pull it free from
the printer.
jams. Damage caused by sharp objects will not be covered by the warranty.
Do not forcefully pull jammed media against the direction of travel through the paper path to
avoid damage to the printer.
When you have removed the jammed media, replace the print cartridge, and close the print cartridge
door.
After clearing a media jam, you might need to turn the printer off then on again.
NOTE When you add new media, remove all of the media from the input tray and straighten
Sep 25, 2011 | HP LaserJet 1020 Printer
Printer hp 1020 in it when we print command of more then two paper the second paper jam (half inside and half out paper does not reach to Teflon part section . single paper printing is OK no pro....
Clean the Paper Feed Rollers with wet cloth.Then go to start-ControlPanel-Printers-select Hp1020 printer-properties-features-change the Paper Type as PLAIN PAPER.
May 23, 2011 | HP LaserJet 1020 Printer
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
Paper jam error after last page prints
Hi Natoli3,
This could be a mis-match of paper sizes. Example, computer could be sending an A4 page to the printer. The paper size in the could be set to Letter. Ensure the 4 paper sizes match, in the computer - the document and printer driver; in the printer (change in control panel) and paper tray (adjust the physical side and length).
S88
Oct 23, 2008 | HP LaserJet 4100 Printer
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
29 people viewed this question
Clive
Clive
