Question about Dacor Ovens
How to slide the oven out
My Dacor mcs 130 oven stopped working. The only thing that goes on is the light. The door lock is stuck in open position. A repairman thinks it might be a breaker problem but he couldn't slide the oven out to check if the power is getting to the oven. Should the oven slide out easily or is there a step that he missed?
6ya staff
SOURCE:
catriver
Ron Marek
  • 878 Answers
SOURCE: Oven stopped working, door stuck in lock position
Tuck, sounds like your Thermal cut out opened on the back of the oven. You will have to get at this in the back of the oven. Part number 4451442. Look it up on the net so you know what your going after. This is a common deal on built ins. Going to need some help in pulling the oven out so far, removing the back panel and changing the TCO...Catriver Post back.
Posted on Oct 21, 2006
Anonymous
  • 8 Answers
SOURCE: Kenmore oven locked
Hello dktshopping,
I know you probable don't want to hear this but in you circumstance, I think you would be better off to contact a repair professional. Those oven door locks are meant to keep the door from opening during the oven's self-cleaning cycle. They are both mechanically and temperature controlled so that the door can not be opened when the oven is 950 degrees. It sounds to me as though something is not releasing to allowing the locking mechanisim to disengage from the door even though the lever is in the unlock position. The unit will probably have to be taken apaprt to remedy the problem. Good luck.
Posted on Nov 29, 2008
David Shaub
  • 2976 Answers
SOURCE: oven won't heat
Check your main panel. If you ran it for a long time with the door open, the elements never reached their shutoff temperature. Quite possibly, you burned them out.
Posted on Feb 19, 2009
Bob B
  • 272 Answers
SOURCE: Dacor CPO230, can't get lock to engage for self
For some reason the oven thinks you have a door that is not shut all of the way. Check the locking slot to make sure that there are no obstructions. Make sure that you are only doing one oven at a time, and not trying to cook in the other. Make sure you have no racks in the oven. Try pushing lightly on the door when the lock engages. For some reason your lock isn't engaging fully and that's why door is flashing. Good Luck
Below is from the owners manual for your oven.
Oven does not self-clean Door not shut tight Check for obstructions. Close door tightly
Oven set for delay timed cleaning Oven will start to self-clean at preset time.
Press CANCEL/SECURE to return to
normal operation
Double ovens only: Other oven is on. Turn off other oven.
Posted on May 10, 2009
SOURCE: dacor 1.5 years old convection oven...not heating
Flip both oven breakers HARD to the "off" position, then back on. If it did not help - you might have a problem with a relay on the control board or a failed bake element.
Grab a flashlight and check the element on the bottom (if you can see it). DO NOT TOUCH THE ELEMENT! If you find any bulging or cracking on the element - it'd out. Before removing the element turn the oven off on the breaker panel.
PS Model number is needed to find the part numbers.
Posted on Oct 22, 2009
How to put oven door back on after removing!
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
Jan 08, 2010 | Whirlpool GMC275PD Electric Double Oven
Light goes off and on by itself
I have the same problem with a DACOR ECS 130 and also set the breaker panel switch to OFF to prevent the light from turning on-off or staying on. It might help to unplug the touchpad connector behind the control panel or it may be a problem relay on a circuit board. I've had the problem for several years but will start work on it tomorrow because we do not bake often at my house.
Bill (bsquared37@yahoo.com)
P.S. I'm not an appliance tech but have had problems with the DACOR DM024 microwave( made by SHARP) and the DACOR raised vent. I think DACOR products are junk. The raised vent problem required replacing the entire circuit board!
Aug 30, 2009 | Dacor ECS130 Epicure Electric Single Oven
My DACOR + ECS 130 covection oven light relay keeps clicking.....
I have the same problem and sent an e-mail to DACOR. A James Carlos responded and advised that DACOR could not provide DYI info because of liability problems, pure BS in my opinion. I've had problems with a DACOR microwave (manuf. by Sharp), my DACOR wall oven Model ECS103 and my DACOR Raised Vent system and told Mr. Carlos so. I don't know how to fix the blinking oven light other than cutting power at the circuit breaker panel or removing the two light bulbs which other have advised but suspect a new front control panel is required. If you find a fix, please advise me at bsquared37@yahoo.com. I think DACOR products are overpriced and junk.
Thanks, Bill 12/10/2009
Aug 27, 2009 | Dacor ECS130 Epicure Electric Single Oven
Dacor CPO230, can't get lock to engage for self cleaning. I follow step clean symbolcomes up door lock moves into locked position then beeping starts and the word door flashes and the lock opens up.
normal operation
May 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
Kenmore oven locked
Hello dktshopping,
Nov 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Jenn Aire lock for self clean in locked position
The LOCK INDICATOR light must be OFF. This can take up to one hour!!!
Do NOT force the door.
Leave the SELECTION and TEMPERATURE knob alone. The Temperature knob MUST be set to CLEAN
Indicator Light OFF, knobs set to CLEAN - OPEN the slide lever.
Lever open, set the knobs to OFF and away you go
Oct 26, 2008 | Jenn-Air Ovens
Locked latch on the self cleaning oven
try wiggling the door latch to get it open if not try the cleaning process, if that works, and see if the door comes unlatched and the light goes off. if not the lock light switch is stuck and it will need to be taken apart and cleaned
Oct 13, 2008 | GE JKP15 Electric Single Oven
How to find discontinued Dacor oven part?
Here's a link with a pdf file that lists your part #82810 for $202.31. http://ww1.dacorservice.com/PartsCatalog/docs/Links/2.pdf. The date on the pdf is 6/12/08. You can also locate a dealer or authorized service providor for Dacor applicances at: http://www.dacor.com/Customer-Care/Locate-A-Servicer.aspx. Good luck!
Jul 20, 2008 | Ovens
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works
I also have a Dacor Model PCS130. This solution worked AND saved me from spending $50-$105 for a service technician to come out just to look at the problem. The high temperature sensor tripped when I kept the door open part way while broiling (never listen to friends who don't have the same oven as yours). Afterwards, I couldn't get the oven to go above the prebake temperature of 135°F using any of the settings (bake, broil, convection bake, etc...). I called Dacor customer service and they told me about the high temperature sensor but wouldn't say how to reset it. They suggested I call a third party technical service company and gave me their numbers. But, I'm glad I found this site... All you have to do is open the oven door and you'll see the grille/grate/steel cover plate where the door latch sticks out of. If you look inside, you can see the electronics that operate the door latch as well as the temperature sensor unit a little farther back. You can even see the RED reset button. But, it's a little too far back for you to press it without removing the cover plate. 6 screws is what holds my cover plate in place. Once that's off, you can reach in and press the RED reset button (I pressed it twice just to make sure) and you'll hear it click. Screw the cover plate back in place. Close the oven door and test it out. It took my oven about 5 minutes to heat up past 135°F so I was unsure if the problem was fixed or not during that time. But, once the oven heated up sufficiently, the temperature began climbing fairly quickly and I was able to breath a sigh of relief. It works! This is such an easy fix, I don't know why Dacor customer support doesn't just tell us how to do it ourselves instead of paying for a service tech to come out and do the same thing. Even better, maybe they should make the reset button more easily accessible (like on the control panel) if they're concerned about people getting in and messing up the other electrical connections when trying to reset the high temperature switch. Computers are far more technically advanced than your oven and THEY have reset/reboot buttons right in front.
Nov 11, 2006 | Dacor ECS127 Epicure Stainless Steel...
Ovens Logo
52 people viewed this question
Top Dacor Ovens Experts
Tyler T
Level 1 Expert
Jaime Hernandez
Paul Bade
Are you a Dacor Oven Expert? Answer questions, earn points and help others
