Model MAH8700A
Https://www.manualslib.com/manual/100313/Maytag-Mah8700a.html#manual
Go to link above. It's the operation manual from the model number you listed. Has some component testing and troubleshooting info. Also, page 7 is the how to get into "service mode"procedure. (Diagnostic Mode ). Machine goes throught a self check. I would try these things first before buying parts. You will need a decent multimeter to check voltage and resistance if you know how to electrically troubleshoot.
Other than this, your basically just changing parts out without proving and disproving. Hope this helps.
SOURCE: 9 cycle heavy duty 2 speed washer machine
Buba, check the lid switch for proper operation, on a lot of models if the lid switch is bad, no spin, no drain. You said you had the pump checked out. Im assuming that it was removed to check for a sock or other garment lodged in the pump. Other things you can check would be the hose from the pump to the tub, make sure it's clear and the drain hose where it exits the washer. Hope this solves the issue..
SOURCE: Maytag washer won't spin out
Before you try to take the panel apart to remove the timer you need to check that the electrical connections to the pump are o.k. and whether the pump is getting power when it's time to drain. If you have to replace the timer you need to take the back panel off first.
SOURCE: Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
SOURCE: Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
