Go online look up ual dv271 bt u will find image of wiring
Hi there, in reality it does not work that way. The proper way is to contact the company that makes it and become a authorized service and repair person with the company which often inn wolves you paying for it, next after approved you need to buy the access to schematics from the company. Alternatively you can ask you question to get a better answer. You should also post pictures and picture of the circuit board where it connect, list you capabilities so I know what instructions to give, be ready to use a multimeter or a volt o meter.good luck https://www.6ya.com/mr.mike
SOURCE: Need a Nak CD-45Z wiring harness, or diagram
Rob, I had the exact same problem, I kept searching on line and came upon Alex in Australia, he deals in Nakamichi products, and has the part (plug/wiring harness). He charges $55 for the part and $30 for express shipping.
Here's his email:
[email protected]
I have also found a site with the Manual: http://www.nakremotes.com/default.htm
Click on "Model List" and look for your model, in the manual there's the wire color code for the pinout. I also have the pinout by wire color, no room to include, will send in another response.
TOP
[ 1 2 3 4 5 6 7 ] Looking @ pins in socket
[ 8 9 10 11 12 13 14 ] Naka CD45-Z deck
Note: The above diagram is done from the perspective of looking directly on to the connector pins. If you are having trouble figuring out which way is which, just use the ground wire, which is always black, as a reference for making sure you are doing the pins correctly.
SOURCE: i dont have a wiring diagram for the 16 pin plug
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
SOURCE: wiring diagram for a road king 56 4 pin mic
4pin roadking 56 wires came off need to know where they go 1 thru 4
