Question about Frigidaire Washing Machines
How do l lower the cycle time from 1 hour to about half hour on top load washer Frigidaire model# fftw4120sw1?
  • Frigidaire Master
  • 26,846 Answers
You use the Quick Wash Cycle if it has one.
Posted on Jan 31, 2019
SOURCE:
  • 125 Answers
SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
Posted on Jan 06, 2008
  • 156 Answers
SOURCE: leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Posted on Mar 03, 2008
SOURCE: my washer won't stop filling
I have a Maytag that had that problem. Mine has a plastic tube inside of the machine that connects to a sensor. As the water level rises, some of it goes into this tube creating air pressure on a sensor that signals the machine that the water is at the selected level. The bottom of the tube had come loose and just needed to be put back onto the fitting. I accessed this tube by lifting the top of the machine, and it is in the back. Very easy to get at. I hope this works for you.
Posted on Sep 22, 2008
  • 196 Answers
SOURCE: Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Posted on Nov 12, 2008
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
Just bough a used frigidaire stackable unit model FEX831CS and washer makes extremely loud noise on spin cycle. and dryer takes over 2 hours to dry a regular load of clothes. Please help
Hello uucyc1 - From what you have described it sounds like you either have a problem with the washer tub bearing, belt, motor or trunnion (steel bar that secures the inner basket to the transmission shaft). As far as the dryer, long dry times typically are a result of poor air flow. Make sure that the dryer exhaust vent is completely clear and that the unit is not overloaded. I would suggest contacting an experiencing service technician to determine the precise cause to both units.
Mar 02, 2013 | Frigidaire FEX831CS Top Load Stacked...
Front load washer FTF530FS1 stop mid cycle, sometimes for more then an hour, then starts up again, entire cycle can take more then 3 hours? Also during cycle is very loud.
Seems you have possibly 2 problems. One, check to see if the element is not faulty. If no heat during heating cycle, the washer wont proceed for a long time.. Two, if noisy, especially on spin cycle, the bearings (2 of them) and the seal are faulty. Replace them as soon as possible.
May 27, 2010 | Frigidaire FTF530FS Front Load Washer
Questions about control panel-Frigidaire tumble washer
if you look in the internet you can download info and instruction free
by giving the right model
anyway ther are green cycke temperature cycles and others the temperature byt the lightest will go for about ann half hour and hottest to an hour and hour and half
try with first cycle and then all others if not sure with a rag that you do not need
ther can be cool cycles also
most machine are the same
try and go to a shop and ask as you want to buy one and if on auction as ebay ask other copy of manuals
Jul 16, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Washer won't fill for the rinse cycle
For this problem you should call service.
If it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
Try :
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a solution solved rating in this site
Thank You
Neil
Aug 18, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
37 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
