Watch this video.
https://www.youtube.com/watch?v=uj_6U46pnn8
SOURCE: how to change planer blades
you will need the directions from the owners manual , do not guess at this it can be a hazard if not done properly i have manual and will try to look it up and figure how to get the info to you
SOURCE: FITTING DETAILS FOR MAKITA PLANER BLADES
It depends on the planer blade set that you are using. If you are using the the 2 sided blades there is a guage that goes with it to set the blade depth before installing. I would strongly recommend that you go to Makitatools.com and type in your model number and download a copy of the owners manual for specific instructions. Let me know if you have any problems finding them
SOURCE: Delta 12 inch thickness planer blade change
Go to this link and at the bottom center of the page insert your model number. You will be able to download the manual for that machine.
Delta manual
If your question has been answered, or I fixed your problem, please take just a moment to rate this post...thanks!!
SOURCE: how to change blades in planer
Go to Dewaltservicenet.com and type in your model number in the middle of the page at the bottom. Select the model number I looked at a type 2 and click on it on the next page find instruction manual on the left hand side and I did have to click 2 times before it brought it up but it is there I just read part of it. The manual is about 17 pages long but the page you need is 11. Let me know if there are any problems please and if I have helped in anyway would you please rate the response accordingly.
