Water Heaters Logo
Renae Riutta Posted on Jan 31, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My heat tape around my water pipes light is flashing. Is it not working
medanielson
Level 1:
Habit-Forming:
  • Contributor 25 Answers
  • Posted on Jan 31, 2019
medanielson
Contributor
Level 1:
Habit-Forming:
Answers
25
Questions
0
Helped
8110
Points
48
May have overheated. This could be an automatic shutoff. Try unplugging for 30 minutes or more and try again. If it works , keep an eye on it. If it keeps ending up going back to the red lights, it could be overheating and be a fire hazard
Steve Pack
Level 3:
  • Water Master 7,128 Answers
Steve Pack
Water Master
Level 3:
Answers
7128
Questions
Helped
2275427
Points
27972
It has failed, 2 options do nothing or replace it. Heat tape is disposable item and they fail regularly
How do I make heat tape to wrap around pvc pipe & heat under my planting flats for starting seeds OR for wrapping the chickens' waterer? Thanks
I started seeds on a pet warmer pad that I got at Runnings. It is just a hard plastic rectangle that stays just the right temperature. For pipe a heat tape product is the choice, look for a self regulating type like Easy Heat freeze free brand. Basically you run it along with the pipe and attach it with tape or zip ties. Maybe spiral it around a big pipe. Insulation around the whole works is a good finishing touch. For chicken water my dad used to just have a 100 Watt light bulb shining down on it, and that worked in South Dakota so probably will work anywhere. The water was inside the coop, so a lot warmer than outside. A loop of heat tape around the bottom of a metal water pan would probably work too. The light bulb also gave light to the chickens to keep them laying more eggs.
What tape can be used to fix cable to pipe
I would consider using zip ties rather than tape
1helpful
R85 tankless water heater
Probably frozen. Let it thaw out and see if it works. You may want to think about wrapping the pipes with heat tape because of those low tempertures they could break especially if the unit is outside.
Good luck,
Marty
Rhepre 40-4 wtr heater leaking from cold water intake
Firstly, don't confuse condensation on the pipe with a leak. The cold water inside the pipe makes the pipe cold. The warmer air around the pipe causes condensation to appear - much the way a glass of cold water "sweats" on a table in a warm room.
Next, determine exactly where the source of the leak is. If it is at a soldered or threaded junction of pipes or pipe an tank, you should be able to solve it - if you know how to solder.
You'll have to power off the tank at the circuit breaker (or shut off the gas supply if not an electric type) before doing anything else. Next, shut off the cold water supply to the tank. This valve must be on the supply side of the leak. If the leak is ahead of the valve, you might need to shut off the water to the entire building. Then, open the closest hot water faucet. Finally, lower the water level of the tank by draining the tank from the bottom valve (you'll need to connect a garden hose to it and run the end to the outdoors, shower drain, toilet, etc.). Keep in mind - the water will not drain "up hill". That means the end of the hose must be lower than the top of the tank. You do not need to drain the entire contents of the heater unless you need to physically move it (or if it is a natural gas or propane type - as a licensed plumber or pipe fitter will be required to disconnect / reconnect the fuel line). A few gallons of water should be enough to allow working on the pipe without causing spills.
Disconnect the cold water supply pipe from the tank - above the source of the leak. You may have to do this by un-soldering the nearest pipe coupling with a propane or mapp gas torch. Soak a thick cloth in cold water and wrap it around the pipe at the tank's inlet to prevent the heat from the torch from damaging the plastic inlet fitting inside the tank. If the inlet connector is melted or damaged; the entire tank must be replaced. Additionally, you might need to unsolder the hot water piping to get better access to the cold water pipe. Only disconnect as much as needed to do the job.
Once the pipe(s) are disconnected, remove the section of pipe that mates with the leak. You will probably need wrenches to unthread pipe sections or fittings so that you can carefully inspect the male and female threads. Fully remove the pipes & fittings and obtain replacements as needed.
You might want to think about installing unions on the hot and cold water pipes. These will make future removal of the tank very easy with no need for soldering. Doing this will increase the time it takes to do the job this time, but simplifies tank removal in the future. You're already into this job - and its only few more extra steps.
Before reassembly, you should provide several wraps of teflon tape around the threaded portion of all male pipe threads. Telfon tape is highly suggested as it is clean and very easy to work with when compared with pipe dope that is applied with a brush. Carefully thread the pipes into the fitting(s) on the tank hand tight. If you are presented enough pipe or fitting to hold the tank inlet fitting, do so with a wrench. Use a second wrench to fully tighten the pipe into fitting. If there is no way to hold the inlet fitting, use a wrench to tighten the pipe about an additional full turn. Always use two wrenches to tighten pipes into fittings when possible. Make up any other threaded fittings (unions, etc.) and pipes as needed. Dry fit the copper pipes together - cut long pieces and replace short pieces of pipes as needed. Once all the pieces are are the correct length and fit together properly prepare for soldering. Clean the outside ends of all copper pipes and insides of couplings and connectors to be soldered with emery cloth, sand paper, or wire brush tools designed for expressly this purpose etc. until they are fully scuffed up and are bright and shiny. Wipe any dust and debris from the pipe with a clean, dry cloth. Try not to touch the cleaned parts of the pipe with bare hands. Apply a light coating of soldering flux to the cleaned ends and fit the pipes with couplings together again like the dry fitting earlier. Place a wet cloth around the pipes nearest the inlets (as before when removing the pipes) once again.
Heat the couplings and fittings one at a time with just enough heat to cause the solder to be wicked into the fitting. It is important not over heat the fittings or pipes. Be sure to let solder flow all the way around the pipes and into both ends of the coupling to ensure a complete solder seal both in and out of the coupling. Wipe away excess solder with a wet cloth to keep your work good looking. Once one fitting has been completed, go to the next and repeat until all fittings and pipes are soldered and clean. A good soldered joint should have a ring of solder visible all the way around the pipe inside the edge of the coupling.
If you've never soldered before, you should practice before doing this repair. Botched soldered joints could result in water damage and additional repair work that is greater than the original problem. Of course, a licensed plumber will make short work of this job and is an excellent alternative to DIY when money for the repair is available.
Hot water is spraying out the plastic coupler that comes out of the water heater up to the pipe. Want to know if there is any way to fix this problem in expensively.
First thing to do is wrap rag or towel around spraying joint to localize water.
Next, turn off power to water heater.
If gas, rotate knob to pilot so pilot light stays lit but burner does not come on
If electric, turn off circuit breaker.
Close cold-water shut off valve above tank.
Open tub valve to release pressure on water heater.
Wait for water to cool before working on water heater to avoid high pressure scalding water.
When finished, make sure tank is full of water and water comes out of tub valve before turning on power.
Water heater should not have plastic couplings.
I can't see your problem exactly, but water heaters have 3/4" nipples coming out of top.
Easiest solution is use flexible connectors from Lowes or Home depot.
Flexible connectors are 24" or 30" long and have 3/4" nut on each end, so disassemble existing pipes using pipe wrench.
Lowes and Home depot can help you select appropriate pipe >> take several phone-photos of your pipes to home center so they can see your problem precisely.
Attach 3/4" male adapter on end of pipe.
Attach flexible connectors between pipe and water heater nipple.
Cold water line has shut off ... make sure this attached to nipple marked cold.
Make sure hot pipe is attached to nipple marked hot.
Use teflon tape on threads.
Add a comment if you need more help.
1helpful
3answers
Bosch tankless GWH 2400 ELP in use 2-1/2 years. Whenever it is below freezing, we have problems with EC and/or EA errors, and no hot water. Sometimes restart will work. Bosch customer support is useless. I...
are u using well water or hooked up to city line if well water --may be to cold for unit if water is below a certain temp unit usually goes into error or shuts down if un heated space where water heater is u may have to warm [ insulate ,heat tape etc]the incoming water usually water that around 40 degrees causes problems
3helpful
3answers
My boiler is not working, not heat, no hot water, red alert light flashing? I dont know how to reset the boiler or het it going again. Its a Worcester 24i junior. Help! Im very cold!
your condensation pipe may be frozen get a hairdryer on it or a hot kettle that should sort it thats the whit pipe on the left usualy plastic
Installed new water heater today. No problems,
did you place Teflon tape around the outlet nipple? you might have to remove and wipe off thread then reapply Teflon tape then put a layer of gasoila pipe dope over the tape then make sure it is the female adaptor is cranked down tight
2helpful
2answers
Water heater leaks on top
Make sure to use pipe dope(compound) or teflon tape on the threads. If you use the tape make sure to wrap the tape in the direction of the threads. Don't over do it with the tape 5 or 6 wraps should be fine. I prefer pipe dope myself....Joe
Top Water Heaters Experts
vince
Steve Sweetleaf
Steve Sweetleaf
Are you a Water Heater Expert? Answer questions, earn points and help others
