4 D batteries or 6v ac adapter. The base unscrews to get to the battery compartment. If you use Ni-cad batteries then take out of lantern to charge. Take batteries out if you use ac adapter. The ac adapter plugs into the back. These are cheap made in china lanterns and the batteries cost more than the lantern.
SOURCE: Magellan Explorist 500 LE Power
eXplorist units have also some hidden and service functions. Like, if unit is off, you can to press:
- IN + PWR - to full selftest of unit (screen test, keypad test, NMEA test)
- OUT + PWR - to serial port test
- ESC + PWR - to burn-in process
- LIGHT + ENTER + RWR - tp uploading of new firmware
- NAV + PWR - to call Service Function window (see below)
- NAV + MENU + PWR - to force power off, equal remove batteries.
- GOTO + OUT + POWER - clear memory and set all settings as default.
IN + PWR helped to power up my unit.
SOURCE: Cannot charge battery
Hola!!!!!
i had exactly the same problem!!!. I bought my exilim Z77 camera in america almost 8 months ago and on my 5 month i charged the battery and it seemed never to charge completelly. The red light of the charger was blinking all the time. I called customer service and they replaced the batery. This is totally free if u are on the year warantee.So yeah ... the problem is the batery not the charger
hope this can help
:D
SOURCE: inverter won't charge
The problem is the batteries. 1) Check the age of them to assure they are not near warranty limit. If so change them. 2) They must be topped off. I recommend using distilled water within every 30-60 days. Summary: After doing item 2 above charge them with an external charger; while connected to inverter is ok. Does this help?
SOURCE: I have a Flip mino
Try a different USB port and don't use an extension cable with it either. Make sure the computer you are using is turned ON and stays on during the charging. not sure about the second half of your question, not knowing how to open? and change the battery? If you never opened it to begin with how did you get the rechargeable battery pack into it?? they don't come installed. battery was separate in the packaging on mine. anyhow, there is a little slide button at bottom of camcorder slide the opposite direction, then the whole front of the camcorder slides down and off of the camera. The battery pack goes in. the White plastic that covers both batteries Stays on them do not remove, but if there is a little plastic strip covering the connections remove that. I have the Ultra HD and it also takes regular AA batteries, and you may try that too to see if it will work your camera, if not, maybe something is wrong with the camera.
I am hoping you did not think the rechargeable batteries were already in the camcorder and they got thrown away with the packaging !!!! IF so, then use AA batteries instead. good luck. :)
