Question about Kohler Home
My new Kohler toilet with AquaPiston technology won't flush consistently. Sometimes it won't flush and you manually have to trigger it. Any suggestions for troubleshooting?
    New Friend:
    Problem Solver:
  • 12 Answers
The jet that pushes the water through maybe clogged with calcium buildup.
Posted on Feb 12, 2019
SOURCE:
SOURCE: Kohler 81100 Pressure-Clean Flushometer Toilet
Hi DavidofCA
I am with the Kohler Customer Care Center. My name is Mike. My phone number is 920-208-4622.
If you still need help with this issue please contact me. Thank you
Posted on Nov 07, 2008
  • 687 Answers
SOURCE: Toilet won't shut off
Does it leak from the overflow? If so then the washer at the top of the Fluidmaster needs to be replaced. If it is not going over the overflow then you will need to replace the flapper on the flush valve.
Posted on Apr 11, 2009
This type of flush system can be re presurised quickly by holding down the flush handle for about good 2 minutes, then release , wait for the tank to be refilled with water.
Now you can flush away your inner rotting mess down tube good-by...
Posted on Apr 21, 2009
SOURCE: Push Button - Have to Hold Down Button
I had the same problem. The fix cost me 50 cents (literally). I just placed a quarter on top of the Blue and White flush buttons (not sure of the technical terms) inside the tank and now it flushes properly. It seems that the 2 plastic poles the extend from the faux chrome buttons are just a bit too short.
Hope this helps
Posted on May 02, 2009
manhandy
  • 146 Answers
SOURCE: Kohler Cimarron elongated comfort height toilet not flushing correctly
low water in the bowl is only caused by the float being to high! the gurgles is Usually because of air coming back up through the pipe, check your vent pipe that come out the roof. this will help the draining.
Posted on Jun 24, 2009
Kohler cimarron very noisy when flushed
You probably have one of the newer Cimarron-series toilets that feature what Kohler calls "AquaPiston" technology. These gadgets use the water pressure in your supply lines to pressurize a charge of flush water in the tank, causing the flush water to rush into the bowl at high pressure and velocity. Many Cimarron-series toilets use only 1.28 gpf (gallons per flush), compared to the current industry standard of 1.6 gpf for conventional gravity-flush units. Reducing the gpf rating by 20% requires pressurizing the water in the tank, and the release of pressurized water makes a lot of noise. I'm afraid your toilet will always be noisier than what you may be used to.
Sep 22, 2017 | Kohler Home
When i flush,no water is flushing, nothing happens
I would check to see if the water supply valve is turned on to start.
Is it a new install?
Jun 22, 2014 | Kohler Cimarron 2-PC Elongated Toilet with...
Koehler one piece toilet trickling water into tank
The flapper at the bottom of the tank is leaking and needs replacement.
Feb 08, 2014 | Kohler SAILE ELONGATED ONE-PIECE TOILET...
Kohler toilet-Cimarron is having problem with filling tank with water, fill tube is in the canister center but the level in the tank doesn't rise and toilet keeps running, there is not a flapper and no...
i don't know about your toilet but i googled it and found this it's the flapper and flush valve
https://www.plumbingsupply.com/images/kohler-flush-valve-1044458.jpg
and you can go here and see all the parts in it,hope this helps you out.
https://www.plumbingsupply.com/kohlertoiletparts-cimarron.html
Dec 20, 2017 | Kohler Cimarron 2-PC Elongated Toilet with...
Float does not trigger valve to stop water - continues to run even though tank is full
What kind of flush valve is it? kohler.com shows a couple of different towers with their ingenium toilets. Is it a Kohler item or is it a Fluidmaster?
Usually you adjust water height by turning a threaded rod that runs up and down. See page 5 of this pdf
http://www.plumbersurplus.com/pdf/1058802_2.pdf
Jan 29, 2011 | Kohler Toilet - One Piece with Ingenium...
Replaced the flapper with a new one and the toilet will lose water until it triggers the fill valve in maybe an hour. Is the gasket betwenn the tank and the cistern leaking slowly?
check the fill tube. sometimes they crack, put some food coloring in the tank and that will help you find leaks too. gently squeeze the tube and see if you see water running down the inside of the tube
Aug 02, 2009 | Kohler Toilet - One Piece with Ingenium...
Master bath toilet replaced with a Cimmeron class 6 confort height toilet. The master bath toilet backs up to the hall bath toilet - same wall. The hall toilet is very old. When the old toilet is flushed,...
Kohler is correct. The most likely cause of this problem is an obstruction in the common vent stack that both toilets share. When you flush the old toilet it need more air to flush and will get it from the easiest source (your new water saver toilet). First adjust the float level in the old toilet so it won't use as much water or just stick a brick in the tank to take up space.Second, run a snake down the vent stack from the roof to check for obstructions. Birds will sometimes nest in there.
Mar 16, 2009 | Kohler K-3489 Cimarron Comfort Height...
Kohler Cimmaron Toilet Flush
You might want to check the flush cylinder, to see if it has water in it. It has to be water free, that way the air in it, lets it go down easier, during fill up.
Jan 23, 2009 | Kohler Cimarron 2-PC Elongated Toilet with...
Home Logo
89 people viewed this question
Top Kohler Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Kohler Home Expert? Answer questions, earn points and help others
