Question about Kipor Electrical Supplies
How to fix fault code p-08 on kipor kde45ss3?
2 Suggested Answers
SOURCE:
adnanbhatti
  • 1188 Answers
SOURCE: Kipor 6700TA displaying charge fault (P5)
Check for loose or rusty battery cables. Unscrew the rear cover and locate the red battery wire. Disconnect it and, using a multi meter, check its resistance: it should have a very low value. Do the same with the other wire.
Start the generator and remove battery wires. If the voltage between them is zero then a fuse is blown.
Next open the front panel (where the display is), there you will find two blue wires with covered fuses, check and replace those fuses if found faulty.
If the problem is still there then it could be the charge regulator. Open the back cover by removing the six nuts. Near the edge you will find a component with silver cover resembling plates. There are three wires leading from it. Check resistance between these wires (one by one) and its body: it should be infinite, if not then replace it. remove the charge regulator and take it to a generator spare shop. The person there will further inspect it and will tell you if you need to replace it or repair it.
Hope this solves your problem.
Thank you for using fixya!
Posted on Aug 20, 2009
Kipor KDE12sta generator under/over voltage LED burning, the engine stops after a few seconds
hi
this happens when voltage regulator is at fault .
what happens is that the demand out put is ( volts /amps too high ) and engine power is too low causing engine to stop renew or service voltage regulator
Nov 12, 2017 | Kipor Electrical Supplies
Why unit keeps shutting down after it starts.
Your question is general without specific details. Any one of many things will cause your generator engine to stop running.
Is this question about a Kipor KDE5000TA? If so, your generator is powered by a diesel engine. There are safety shut downs built into the generator to protect the generator head and engine. Do you have any fault codes showing on your control panel display screen? (Trouble codes P-01 through P-05 will be displayed if there's a detected fault)
If you have no fault codes, then you likely have a fuel problem. Do the obvious:
  1. Visually check the fuel level in your tank. DO NOT rely on your fuel gauge. It may be stuck or otherwise not working.
  2. If you have fuel, check your fuel filter. It may be clogged. If your fuel filter is good, you may have water contamination.
  3. Drain your tank and refill with fresh #2 diesel fuel. I use "Diesel 911" with a biocide to prevent water contamination and bacteria growth in my fuel.
  4. Make certain your fuel oil supply and return lines are clear, not leaking, and the fittings are tight.
I know I'm shotgunning, peppering the target. However, I don't have enough information to zero in on a specific area where the problem could be. Good luck!
Apr 26, 2015 | Kipor Generator Diesel Kde5000ta
Airbag fault codes
SB-08-09-41-002C
Mar 18, 2014 | 2010 GMC Terrain
Kipor 6700ta po5 code problems , diesel silent generator
1. Check the voltage of battery whether is 12V or 24V; 2. The voltage of battery is low when the generator is still, then it is necessary to dismantle the battery and charge the battery with charger.
3. If the voltage of battery is low but the generator is running, it indicates that the diesel engine driven charger doesn't work; then it is necessary to stop the engine to check the fan belt.
4. if the fan belt is not loose, please check the charging AC diesel engine driven charger, please refer to Manual for Diesel Engine.
5. If the battery can not store the electricity, please replace the battery for a new one. https://www.dieselgeneratortech.com/generator-sets/discovery-and-elimination-of-faults-of-the-control-system.html
Feb 04, 2014 | Kipor Electrical Supplies
Electrical Supplies Logo
48 people viewed this question
Top Kipor Electrical Supplies Experts
Vernon Taylor
pawnpower
Wayne McNeil
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
