- No damage under the moving. - Never had problems before. - happens when it fills water first time in the process
SOURCE: Water leaking from left side ice/water dispenser
If you describe a constant flow of water from the ice maker then the solenoid valve is either leaking by when it's upposed to be off or the motor module is stuck in the "fill" position. If it was stuck in fill you would be getting a LOT of water all the time so if you only have a trickle then the solenoid valve may be letting water leak by it. The diagram here shows the parts for a better idea of what you may need to look at (and where it's at). http://www.partselect.com/Schematics/Frigidaire/SZGBPCQH.gif
SOURCE: Hotpoint WD64, leaking water from soap drawer
your condenser is blocked,you might be lucky and get away with just cleaning it, but most of the time it is just best to change it. You will have to take the back off again it is the plastic component with the fan motor attached, disconnect the 2 black tubes to it [note where they come from] unscrew the 3 bolts at the bottom , disconnect the wires going to the fan motor. If you are going to change the condensor you will have to take the fan motor off aswell MAKE SURE YOU DISCONNECT THE MACHINE FROM THE MAINS. GOOD LUCK
SOURCE: kitchen sink soap dispenser won't pump
soap may be too thick or pump tube may not be touching soap in dispencer. try pumping same soap from cup
SOURCE: Water coming from soap dispenser
We had water pour out of the dispenser of our Kenmore HE2 washer. hot water helped us for one load then i realize that a trapped rag was the problem We were actually able to pull the face cloth out of the intake tube without taking everything apart!
opened the washer door and feel around inside the rubber seals to find where the intake tube connects to the drum (upper-left side). felt a small bit of cloth sticking out of the tube and were able to slowly work it out by pulling back and forth. and pulled it completely out thats all it was try this fi
SOURCE: kenmore front load washer is leaking water from soap
We had a similar problem with water coming out of the soap dispenser when the washer was run. I assumed that it was a problem with the water draining as everyone else posted here. I took off the front panel, got rid of the junk and drained it. Although this was great, it did not solve the original problem. It turns out that there was a sock stuck in between where the water comes out of the soap dispenser and in to the main compartment. Pulled it out with a needle nose plier and good to go. Thanks to everyone for their input here.
Testimonial: "good to go "
