Have even deleted hard drive. And wiped drive and parties it always comes back and takes over
GW KIM WHAT DOES BUILD MEAN/? (INSTALLING OS
endless reloading THE NEW OS?
NO PC stated, at all,just GW,
NO os STATED, IF XP SURE ITS INFECTED AND WILL BE FOR EVER, RUN W7 OR 10 ONLY, OK?
THEY ARE SUPPORTED ONLY. UNLESS RUNNING LINUX, can't be stopped is Never true. ever. .
so I guess you are asking how to fresh load windows, clean and so that windows itself is not preloaded with virues, as seen on TORRENT Pirate WINDOWS INSTALLER disks. (THE ENDLESS STORY THAT)
so first and USING REAL WINDOWS MEDIA KITS THE ISO FOR WINDOWS IS AT .MICROSOFT.COM" .
if asking why , clean windows work, perfect , then later clients keep getting it infected, that is from reading spam, and clicking attachments and email links or worse going to phorn sites.
if PC is old run w7-32bit load MSE, MS antivirus is free, an educate your clients.
do not run XP,
nobody does now but the last guys sitting in a BAR at 4 AM... die hard's like him,GI joe! HE is wise. WHY ,READ!
http://www.pcdied.com/XP-sux-sg.html
cant be stopped.? the bull snorts, AND SAYS:
1: run top AV (AntiVirus SW)
2: set mail up for no attachments and text only no HTML
bingo mail safe. ok? it's not hard at all ask, (just do it)
3; setup your PC for safe browsing, with full phorn, blocking.
4: run Firefix v60+ it has built in protections. for many known dangerous web sites.
5: keep the windows firewall 100% up (w10 best)
6: keep the router firewill ports ALL OFF and dead 65k ports incoming OFF.
7: educate users. on how not to DL software with out first running Virustotal.com
8: get software from only the official makers sites, do not use (joes nasty software download dot com)
NO PC stated at all just GW, so answers WILL COME HARD (for us)
CAN'T MEANS you can't but all others can.
for sure.(skilled)
total infected HDD.
1: erase it with kill disk.(erase)http://www.pcdied.com/w10/HDD%20erase/er...
(hint for sure all infections are gone. now)
2: buy new windows 7 and microsoft.com
best is ISO version from them and burn a
DVD or burn a USB memory stick 16GB or larger
3: boot the install media now. run the installer,
4: done.
now keeping that clean? ask
a long topic how not to get infected, ASK?
XP is a virus magnet, do not use XP
OK?
run windows 10
run a firewall on 10 and in the router you have at home.
educate users, first.
do no allows email attachments
do not click links in email
do not load programs for wrong sources.
run firefox v60+ for better protection
do not use IE11, (or for sure older)
SOURCE: iPod Classic 3rd party manager
http://www.mediamonkey.com/product_ipod.htm This is a good Alternative to Itunes.
You can keep all your music on the Ipod and delete from the Hard drive.
SOURCE: IBM ThinkPad T40 Hard Drive Problem
HI IM LOOKING FOR THE DRIVRS FOR MY LABTOP T40 I NEED ALL OF THEM I LOOKED IN TO IBM SUPPORT.COM BUT I CANT FIND IT SO IF ANYONE KNOW WHERER I MAY FIND IT HELP ME OUT THANK YOU
SOURCE: set up did not find any hard disk drivers installed on computer
Your notebook has SATA hdd. Got into the bios (keep pressing F2 key on startup) then in the bios screen find HDD and press enter. Select IDE mode. Press f10 to save changes and exit. When this is done install XP.
Alternatively connect external usb floppy drive and unzip sata drivers into that. When booting from xp cd press f6 to load drivers.Follow onscreen instructions to load drivers and continue xp installation.
Please let me know if issue not solved for futher ts steps.
thanx
SOURCE: Duel Hard drive trouble
Your Os should have the main automatically, keep the other drives as slave unless they are usb then they should auto pick up when you start up your pc for sata drives you got to buy sata connectors and make sure your motherboard has more then just 1 sata connection. After you find out how many you have on your motherboard from bottom to top is 123 so if u have 3 then if you want like if you have a music hard drive and you want it to be first then put it at the bottom 2 and so on.. don't forget to set them as slaves
Testimonial: "EXTREMELY fast responce !"
SOURCE: I need to wipe my hard drive clean. Where do I go
What brand and model is the laptop? You might have to buy them from the manufactore but on some computers you can create them yourself
Hi Kim force, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
no mention of OS at all, we can't help you lacking that(XP?) or what GW model this is.
not possible to help , only GENERIC ANSWERS GOOD BELOW!
