I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
No lights come on the charging cradle at all (with my daughters Casio EX-Z57 and camera won't charge. Battery is inserted properly and cradle all wired up right (have even checked plug fuse). Any thoughts
