SOURCE: changing belt on vacuum cleaner
If you can't see the motor shaft then you will have to take the top cover off. Some have a couple of scres to remove from the bottom. Then is a slot on each side, from the bottom put a flat blade screwdrive in the slot and push out and up to release the locking tabs. The knob may pop off so watch for that coming off. Put the belt on the brush roll, then feed the belt up thru the opening and stretch it to go over the motor shaft. Put back together.
SOURCE: belt replacement on GE top loader WJSE4150B2WW
Your post shows a model WJSR2070B and a model WJSE4150B2WW but in this case the procedure is the same. Use a putty knife to push in the clips at the top seam of the front panel, where the front meets the top, about two inches in from each side. Tilt front panel forward and lift off bottom pegs. Loosen the four nuts holding the motor with a 3/8 inch wrench so you can push the motor back a bit. Take old belt off. Install new belt (WH1X2026), putting belt around motor pulley, part way on big pulley, then turning big pulley by hand to ride it onto the big pulley. Use one hand to pull motor toward you to put a little tension on the belt as you tighten the four nuts under the motor.
SOURCE: need to know the exact
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
SOURCE: my dryer belt broke
i need a diagrame of how the belt goes on the drum . dryer is a roper 386567 3 cycle 2-384
SOURCE: REPLACE BELT
Hi there ,
how do I get the belt around the drum ? do I have to take the whole back panel off the dryer ?
Don
