Please show me gear fuse my gear is not working well is not moving for driving how can me doing it
posting about CAR Fuse on computers, really?
and hyjacking too>?
I got this free Pdf manual from an online store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the all the times I fixed the chipper in these 4 years
FIXYA IS USA, ARE YOUR?
SORRY OP, THE BATTERY DOES UNPLUG
THE SERVICE MAnual covers that action.
any time any laptop notebook (portable) fails
we unplug the battery.
they short out and overload the power rails.
you can try the long power rest,
remove AC power pack
hold power button for 10 to 30 seconds,
release button.
putback ac pack pray
then remove battery pack connector
if all this is scary any shop fix it.'
IT DOES UNPLUG.
N541SA , USA MODEL
ASUS.COM
horrid web site there to navigate, maxhttps://www.asus.com/us/supportonly/R541...
no service manual (toy class PCs it is)
users guide tells you get PC serviced for battery.
forcing this step, youtubehttps://www.youtube.com/watch?v=h2w9gKjR...
not tech there not breaking 2 very fragile
connectors doing so (PAD and KBD ribbons)
HERE IT IS, SEE THE SCREW HOLES?
repeatedly press F5 when windows is starting.. try this
IS removable. and is #1 thing to fail in any portable computer.
not dropped, hit, or spill coffee floods.
1st the long power reset, (per asus.com)
if fail try with no big battery next.
or get it fixed in a shop like 99% do.
hold the power button for 10 to 30 seconds
and release with no power pack attached. AC
this is the long rest in the manual
if that fail the shop pulls the battery next.
the shortest live part in the PC is the battery
a hard cold fact of life.
and is first thing to test and discount.
we simply unplug it, if that is scary to you
get it repaired in a shop for PCs.
if all this confuses you, batteries, and now hidden why not go to any shop and get it fixed, really like 99% do, for sure, world wide.
I think now about 1billion laptops batteries die each year world wide,(cell+tablets,PC)
it's not like a NEW THING>
in fact planes have crashed with them on board and on fire. a 2nd fact. (air freight 2 times so far)ML370 I bet too !
SOURCE: roomba discovery on full charge
unfortunately the batteries on the roombas can go bad and not hold a charge and need to be replaced, also you should check all the brushes and wheels on the bottom, if they are bound up it would stop the roomba from working. the two brush rollers can be removed by pushing on the two tabs just above them, try and clean any hair from them. if its real bad you should buy the maintance kit from them witch gives you both brushes and filters as well.
SOURCE: Milwaukee jobsite radio Cat. No. 2790-20 120V.
You might want to post this question in a different section. This is the pc laptops section.
SOURCE: asus s200e stuck on high performance mode
Go into the settings menu and set it to "Balanced". The thing you have to remember is that they say "Up To 5 hours" not will run for at least 5 hours. It probably will last for 5 hours on idle but not if you are watching movies on it. They take a lot of processor time, therefore use a lot of power.
SOURCE: how do you take a screenshot on an asus sonic master
If there's a Print Screen (PRT SCN) button, pressing it should copy the display to the clipboard (on Windows machines). Then you can open Paint or about any other image program, paste the screen to it, and save the image.
Hi Trish Amy, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
100% false, the battery does unplug
and 100% true the first thing to fail, a A FACT.
just because they hid it a bit does not magically make it last 25- 100 years, like
the far better parts inside (amazing no?)
the only question is how.
the best plan, as posted here 10,000 times.
1: get any shop on earth to do it.
2: you do it, we don't know what you can do.
there are only 2 choices.. so...
first hit at TOMShardware, bingo
1 screw dirver and a 10cent cell phone plastic pry tool.
most folks not skilled here, break the ribbon cable jacks at step 3, (as case split time) the ribbon connectors are super fragile. (a skill to learn or cry doing)
https://youtu.be/x56SO1sJJn4?t=18
stats USA. only LI-Ion only,
$4 billion in batteries sold (secondary +)
in the us in 2015, see they fail often
life span is 2 to 3 years,
learn this expect this and have a spare for vacation (wise)
https://electronics.howstuffworks.com/ev...
if abused, drawn down deep and often less.
