Question about Maytag Washing Machines
My top loader maytag washer wont dispence the fabric softner
Its the drawer type that has fabric softner on left of drawer and detergent on right but during wash fabric softner quit dispencing
    Top Expert:
  • Maytag Master
  • 52,821 Answers
The dispenser may be clogged with softener residue.
Posted on Jan 30, 2019
4 Suggested Answers
SOURCE:
  • 99 Answers
SOURCE: Water pouring from detergent, bleach, etc.. dispencer. Help!
This is joyce
He is right the Jets are probl stoped up with mold,
you need to take drawer out look to top of machine where water comes into drawer to dispense to your detergetnt, and see if their is mold, if so take squirt bottel full of bleach and squirt it up on the mold and let sit a while and then take tooth brush and scrub off as good as possible, run one cup bleach in machine with out any clothes . on hot cycle. do this 2 times see if this helps .
let me know. it can only help cant hurt.
willl make machine smell better, and never shut door to front loader completly shut, it needs air to dry or else it will mold.
thanks
joyce
Posted on Feb 11, 2009
SOURCE: softner in detergent drawer dispence at the wrong time
Take off the top of the front loader, topfrontleft is the dispenser, there is a movable part that was incrusted and unablble to freely move, clean off parts, little water will do, the movavable piece should move back to the roman numeral one, it is spring loaded, put top back on, done.
Posted on Jan 02, 2010
paulcharmbur
  • 744 Answers
SOURCE: Fabric conditioner dispencer not working
Fabric conditioner wont dispence This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 30, 2013
Bleach & Fabric softner tray not working.
Remove the drawer by pushing the tab at the top of the drawer and pull it out and check for an obstruction. They regualarly plug up with gummy fabric softenener. Try washing out with hot water and reinstall
Apr 04, 2010 | Frigidaire GLTF1670A Front Load Washer
Softner in detergent drawer dispence at the wrong time
Dec 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front loader LG washer drawer for detergent is stuck won't open
Remove the top of the washer by removing the 2 retaining screws (phillips head) from the back of the unit & sliding the washer top back about 2" & pulling up. You will see a white detergent dispenser box with several hoses coming off the back in the left front of the unit (this box contains the detergent drawer). The lid to this box is held on by 8 pressure snap clips. You only need to release the 4 snap clips (3 large, 1 small at the rear) on the right side of the box (nearest the washer drum). Pull up on the right side of the lid while pulling out on the detergent drawer. It should come out normally. Do not reassemble until you read below, then reverse the steps to put the washer back together.
The problem will be the "softener" lid (blue). It will not be sitting down in the drawer assembly & will catch on the lid of the white detergent dispenser box. Simply remove the blue lid to avoid future jambs. It only serves to identify the fabric softener recepticle & it keeps fabric softener from splashing around when water enters the system. You may need to remove the entire detergent drawer periodically to clean (push down on the blue thumb indent inside the drawer to release it from the housing).
Hope this keeps you from drilling through the lid & ruining a $23 part, like I did.
Mar 26, 2009 | LG WD-16115FD Front Load Washer
"fabric softner staining the clothes"
make sure you delute it with water. yes fabric softner will start to stain your clothes if you use too much of it. I would recomend stop useing it for a while. so you can clean the washer out. There is a product called Washer magic or Affresh that cleans out residues built up in your washer. or you can just run several loads of HOT water and bleach to clean it out. The hot water will melt the left over fabric softner in your washer. Fabric softner is kind of like hardend bacon fat thats what it looks like in your washer after time and if you do not clean your washer it builds up and builds up.
Also i do recomend alternating liquid detergent and powdered detergent. The reason why is powder leaves a residue that liquid takes away and vise versa. try this and let me know how it goes
Feb 12, 2009 | Maytag PAV2300 Top Load Washer
This is joyce
thanks
joyce
Feb 11, 2009 | Maytag MAH8700A Front Load Washer
Dispenser tray removal
hi, nikoltheis! i'm not sure if we have exactly the same model, but it should be pretty close. here's what my user's manual says:
Detergent and fabric softner may build up in the dispenser drawer. Residue should be removed once or twice a month
- Remove the drawer by first sliding the safety latch to the right, then pulling the drawer out until it stops.
- Reach back into the left rear corner or the drawer cavity and press down firmly on the lock tab (left rear portion of the drawer). Pull out the drawer.
- Remove the insert from the bleach and fabric softner compartments.
- Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders and liquids. Large amounts of fabric softner residue may indicate improper dilution or that more frequent cleaning is required.
- To clean the drawer opening (the empty area left behind when you remove the drawer) use a small brush to clean the recess. Remove all the residue from the upper and lower parts of the recess. (The picture shows this being done with a tooth brush.)
- Replace the insert pressing "X" to lock it in place. Return the dispenser drawer.
Jan 18, 2009 | Frigidaire GLTF2940ES Front Load Washer
The fabric softner drains out as soon as I pour it in
the fabric softner drains or flushs down in the rinse cycles,,,now if you fill past the line or open in dispencer it will sphion down by it self,,in short your overfilling dispencers,,onthejob
Jan 07, 2009 | Kenmore Elite 45986 Front Load Washer
Leaking detergent and fabric softner
Possible your inlet into the tub from the detergent drawer is clogged; try pulling the drawer out gently to clean out. Or use a tooth brush. If you are good at 'do it yourself ' jobs you could open up the top of the machine to see what the problem is. If the machine is under warranty, call the dealer.
Nov 01, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softner leakage
By opening upper machine's cover you will have an access to the detergent/softner drawer. Look for the place the water leaks from. Good luck !!
Sep 03, 2006 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
