SOURCE: electric surge turned off the clock,oven but the stove top works
do you have both legs of the 220v? on the board see if you have 120v at L1 and L2. if you do then you have a bad board.
SOURCE: MAYTAG STOVE PROBLEM...NEED HELP
the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
SOURCE: stoves 900DFa dual fuel cooker
check to see if one of the oven elements are burned into if you have an oven cord on it turn the breaker off and check the cord where it connects to the oven
SOURCE: amana cooktop
Hello dishmama1, is this a sealed burner cooktop? If so then remove the cap and make sure all the holes are clean. Restricted burner holes can cause and issue with the flame. Also with it off make sure the area where it sits is clean and the cap sits flat. Hope this helps
If
your electric oven is taking too long to heat or just not heating up
right, then check out this tip that will give more detail about your
problem.
Oven
Problems Electric Oven is Heating Slowly or Poorly
heatman101
