SOURCE: my home theatre system (sAmsung
Protection mode on a Samsung player most likely means that the unit is overheating due to a non or low functioning fan. Before taking it somewhere to be serviced turn the unit on and see if the fan in the back is functioning (it should be on whenever the unit is on). If it is not you can try gently blowing it out with a can of compressed air.
I am sure that you can have it serviced but it might be cheaper to purchase a new player.
Good luck and take Care,
-WN
SOURCE: Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
SOURCE: my dvd home theatre system ht tx75 keeps shutting down
I didn't solve the problem,however i called sam sung and I will be sending it in for repairs under warranty.
thank you
SOURCE: rear check message on HT-TXQ120 samsung home theatre
Looks like it is to do with the rear wireless speaker. Now, my problem is over. Its gone. I first turned the reciever on and then turned on the rear speaker wirel less on. No rear chk in problem now. Hope this helps. R.
SOURCE: How to set up 6.1 divinci home theatre system to 42inch HHD LCD T
davinci DA-6.1 home theatre tokk it out of box their is only speaker wires that connect on to another no power source or wires to tv I need help
