IT RECEIVED AND THEN SLOWLY FADED OUT. WILL NOT TRANSMITING NOW EATHER. IT KEYS NO MOD OR RECEIVE
SOURCE: TK 380 not transmiting
Its most likely was programmed with a rx but no tx. Meaning it can recieve but not transmit, you can fix this with the programing software.
SOURCE: Not able to finish transmiting.
1 check and clean mic switch
2 check and repair wires in mic plug
3 if preamp mic replace battery
SOURCE: mororola gp 68 ihave 3 but only 1 is transmiting
Define "locked" Also, you can check out http://www.batlabs.com/gpman/top.html and maybe that will help.
SOURCE: radio keys up but will
sounds like the audio chip is toast. Most of the radios that I have seen have see have the chip mounted on she side.
with the cover off check the component side up...look to 1/3 from rear of unit and the chip is usually seen there.
Good luck !
SOURCE: I'm using d-link dwl-3200 ap
Transmitted Error Count 4734440 Ack Rcv failure Count 15269951
