Ovens Logo
c
corrie Posted on Jan 29, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Goldair split unit and sometimes it show a flashing F1. F2 F7 what is the reason and what does it mean
Kardoc
Level 3:
Top Expert:
  • Ovens Master 7,503 Answers
  • Posted on Mar 13, 2019
Kardoc
Ovens Master
Level 3:
Top Expert:
Answers
7503
Questions
0
Helped
2756997
Points
58323
2 Related Answers
Anonymous
  • 117 Answers
  • Posted on Feb 07, 2009
SOURCE: F2,F5,F7 message
MAYTAG
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Anonymous
  • 142 Answers
  • Posted on May 20, 2011
SOURCE: F1 code after installing oven, cut power to unit
F1 means internal logic failure; control needs to be replaced
F7 means function key shorted (touch pad).
Hope that helps.
When I bake, my oven will start beeping and flash F2, what is that and how do I stop it?
Which manufacturer built your oven? The F2 error usually means that the oven temperature sensor is claiming the oven is too hot (or got too hot in the past). This usually requires replacing the temperature sensor. Sometimes, the control unit (clock) needs to be replaced.
I hope this helps. Please add a comment with the make and model of your oven for additional support.
Mar 18, 2013 • Ovens
I have a flashing code on my kenmore electric oven, model 911.47709200. the code is F7 dc, what does it mean?
Stuck Keypad. Roper ovens with 2 Digit Displays:
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 25, 2011 • Ovens
F1 code after installing oven, cut power to unit for 30 min. then F7 code displayed. What do they mean? This is a model SC302ZS Thank you for your help.
Hope that helps.
7helpful
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F7 Shorted Touch Panel Replace Glass Panel
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
Dec 18, 2009 • Ovens
3helpful
2answers
Our magic chef oven starts beeping and gives us a F1 on the display
f1 indicates a shorted touch pad ,if you want to make sure ,unplug unit ,disconnect touch pad from computer board ,if f1 goes away touch pad is bad.if not replace board
1helpful
Flashing F2 warning
GE
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Aug 18, 2009 • Ovens
3helpful
F7 error code- what does this mean?
Oven Fault Codes
2helpful
F2,F5,F7 message
MAYTAG
Code
1helpful
F1 Error Code
According to the GE website, F1 usually means a problem with the keypad. You might try my solution for the F7 problem which is similar in nature. Go to the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared my solution with more than 1900 folks and most report success.
Please let me know if it works for you at:
[email protected]
Good Luck,
Powerman
Jul 16, 2008 • Ovens
1helpful
F1 Error Code
try fix at http://www.fixya.com/howto/h155060-dreaded_f7_error
this is a common error and easily fixed
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
