When I try to log on I get the message "Recovery Boot Menu" I have tried to select from the menu but everything see,ms locked. What can I do to enable the log on process.
Have you just changed ur battery? If not i would suggest replacing the battery, in the mintime switch off the pc remove from power supply remove the battery. Connect to power again and try switching on without the battery. If it works fine, switch off and put back the battery and try switching on again if it happens again u need to find another battery. Good luck.
no PC stated. why? if over 7 years old 2 batteries are due ,ok ?
leave the big battery out, why make this so hard, removing , (its old shorted overloaded the VRM regulators) leave it out,
now boot, this always first
ever see a battery short as it warms up sure
and then overloads,
just take it out 2minutes work and is always first. (batteries can fail vast ways and be intermittent and have shorted cells) learn that in be successful.
then if it still fails, (vast single point failures on PC, endless, battery is 1st always
no PC stated at all
why post lacking such a key fact
NO OS, stated but you forgot sure.
if the PC fails to run windows, if is windows
and fails to reach windows login screen
ms locked.
does MS locked mean
login screen snows, but the box to type there is dead? or you lost the password.
we cant see your screen , nor errors on the way to this screen.
back up data and do a full recovery?
you sad battery is charged fully !
I say you don't know that'
I can in fact hand you 10 bad batteries,
right now and the silly charger thinks it good, and fully charged.
learn that, and test with the battery out first. to prove PC works on AC then if yes,
buy anew battery some last 1 year.
my last one lasted 2 y
and the before aw 1y.
all expected by me after all IT'S STINKING Batteries.
the 10,000 post of yet one more battery bites the dust.... would make nice song.
other one,
an other one, bites the dust (rimshot bam)
if it fails after big battery out.
next run HDD tests.
if those pass run the manual guide stated recovery, rtm ,read the manual
FIRST OFF NO PC even stated at all, just
(A COMPUTER)(one of 10,000 models by Lenovo)
the recovery window pops?
that means the OS could not boot.
It means, HDD is bad, or OS corruption, or even a bad shorted battery (big one)
why not pull the battery first.
1: big battery out, still fails.
2: IN BIOS FIND THE Hdd TEST. RUN THAT.
IF HDD FAILS ITS BAD.
3: In a real shop we boot Linux media(usb) and run full smart test on any suspected hDD bad. if HDD is bad or weak, its 100% a waste of time going forward with recovery using the recovery partition. or fresh install.
the New HDd must be inserted (exchanged)
if the HDD tests pass. we the open the book
on your unstated PC and read the chapter called
RECOVERY, it does in fact show all ways to do so, if you can read.
at "Lenovo support" page on your PC.
no,OP, the battery is not fully charged it is a bad battery, bad batteries fool the charge chip inside PC. (no charge chip ever made is as smart a any fully trained technician or engineer)
not one. (someday ,.maybe but not now)
pretend in your mind you are a battery.
and all cells inside are now 1/100/th of new capacity, and the silly PC thinks(sick) it's charged. the poor thing...…..
or as most do this , this old short out. and overload the power rails inside causing
electronic CHAOS.
learn to test all laptops with no big battery first ,learn that, do that and win.
its like 5minutes work remove it and test .
on AC pack only, or even run like that forever.
the error means the HDD can not boot
there are 3 causes.
1: HDD bad.
2: OS corrupted.
3: kids played with it and bingo deadsville.
NO PC even stated, just PC.
Lenovo.
impossible to go farther lacking such a key fact, full model numbers off the service tag.
We can't see your screen,
nor guess.
why not first remove the battery huge.
run on AC pack only
see it works like that endlessly does it?
the first thing to fail is that. shortlived. NO PC stated no OS stated no screens shown strike #3 im out.
im guessing the OS is corrupted, non stated
when recovery pops that means files corrupted.
bad hdd, or virus hit.
SOURCE: Notebook will not boot
If I understand what your problem is...
I had the same problem, it was a caused by bad Windows XP install CD.
Call Gateway and explain the situation, you may need to have a magnifying glass handy to read the tiny engraved lettering in the center of the CD disk.
Have your 'Product Key' available.
If you have some kind of sales receipt, or other "Proof of Purchase" have it handy too.
You will need to tell them, you do not have the program installed on other computers.
They can send you another disk.
This method will only work if you have a legal copy of the program.
SOURCE: Computer won't boot up
you must hold down the F10 key( for system recovery) when you turn on computer. hold down as computer starts up,hopefully it will then repair itself and boot up. If not,start up computer holding down F12 for advanced diagnostics and run some test!! Good luck
SOURCE: acronis loader fatal error- I can't boot up !
if your pc starts ok with no cd in than do it like that if you see this error all the time it means your hard drive is shot, or erased, or partially erased and needs to be setup again or replaced. got nothing to do with acronis if it does this all the time even with no cd in drive.
SOURCE: Cannot identify Battery
When I turn on my Dell Inspiron 1501 laptop, I get this:
Warning: the battery cannot be identified.
This system will be unable to charge this battery.
Press Any Key to Continue.
Press <F2> 2 times to enter SETUP.
Press <F12> and Any Key to enter Boot Menu.
what should i do?
