The length of the probe does matter, it has to do with the design of the heat exchanger, ect,, will it operate?? yes it probably will, but it is more of a safety issue. Official answer is use the same length,, some people do fudge the length, but it is not recommended. I know I'm dancing around the point,, because it is a liability issue.. If you can, really try to use the exact replacement as the factory part. Sincerely, Paul
SOURCE: need the cubic inches for the return air duct
For proper minimum opening you need to do duct calculation. This is not a typical math equation for the typical homeowner. And unfortunately alot of contractors do not take the time to calculate this.
If you insist on doing this yourself...... I would recommend the largest opening that a common filter will fit. probably 20" by 25". Going to big on a return air will never hurt. But going to small will.
20" x 25" will work safely 95% of the time. But... If you are running airconditioning that is 5 tons in size, you will need the design a return air system that will feed from BOTH sides of the furnace.
If you are just sizing the trunk line you should use a ductulator to calculate the minimum size. A good rule of thumb would be to size the "return air" trunk 1 - 1 1/2 times the size of the supply trunk line.
SOURCE: How to divide 12 11/16 inches into 71 3/8 inches?
you will need 5 full planks = 68 1/4 inches and the last board will need to be 3 7/16 inches wide.
SOURCE: my goodman furnace is blinking led 4 times i
check the flame senser connection it tight to the board and that it is clean or try looking at the fault codes again they are online you could check the air fliters are clean
SOURCE: blower fan running constant after new fan and
Here's my best shot.
Check the temperature settings for the fan switch.
The low OFF setting should be about 100 degrees.
The ON setting should be around 150 degrees and this is the setting that "makes" the ON contacts.
The HIGH LIMIT setting should be about 180 degrees.
If these are set, can you use a meter to see if the FAN ON contacts are closed?
Lastly, it appears that one hot line should go to one side of the blower and the other hot line should go to the bottom FAN terminal with the other side of the blower being fed by wiring from the top FAN terminal.
Good Luck. Gary
